Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: clutch life  (Read 1811 times)
Re: clutch life
« Reply #10 on: January 09, 2019, 07:35:01 PM »
Don't know, either, 'bout the TC?
But, the judder could be caused by insufficient oil inside the clutch? Often, the symptom is also accompanied by some noise -- like a "squawk"?
If that's suspected, running (whilst immobile) with the clutch dis-engaged and the plates, hopefully, separated my allow some more oil inside. Another remedy has been to drill more holes in the inner basket to allow more oil in.
A change in engine oil (brand/type/vis./?) may help?
Shouldn't be a design issue on a '16 model. Mebbe giving it too much beans. I've never had a clutch problem on any bike.
Re: clutch life
« Reply #11 on: January 09, 2019, 11:29:24 PM »
Agreed, the fiber plates may not have gotten a good enough initial soaking?
(may've missed it altogether..?)
How's yer rear tire life..?
"Working on a motorcycle, working well, caring, is to become part of a process, to achieve an inner peace of mind.
The motorcycle is primarily a mental phenomenon."
Robert M. Pirsig
Re: clutch life
« Reply #12 on: January 10, 2019, 01:05:22 PM »
It's ok normal riding, bit of judder when I accelerate hard from a start or overtake. Sometimes forget which bike I'm on. Dunno if the TC would this, do you have it?
Tyre wear is fine, I'm usually going places, not squirt & brake.
Offline healdem
  • ....has a fluffy tube
  • Bike: 2011 Tiger 800
Re: clutch life
« Reply #13 on: January 10, 2019, 01:30:33 PM »
just wondering if you have the OEM handguards?
if not thoroughly secured they can rotate and put slight pressure on the levers.
I've had it on the clutch levers a couple of times, someone I know on the front brake.
Re: clutch life
« Reply #14 on: January 10, 2019, 01:39:02 PM »
Nah m8, wish it was so simple. Anybody else with TC had this wee judder?
Offline healdem
Re: clutch life
« Reply #15 on: January 10, 2019, 03:48:16 PM »
sorry was responding to the OP and his alarmingly short clutch life...
Re: clutch life
« Reply #16 on: January 10, 2019, 03:55:18 PM »
Ok m8, the OP sorted his, he fitted a new clutch back in July.
