Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Ignition coil removal  (Read 983 times)
Offline The Reaper
  • Bike: 800 XRX
« on: August 07, 2018, 12:04:57 PM »
Quick question guys, how do I pull off the ignition coils on a 15' xrx?  in the middle of doing my 6000 mile service and the coils will not pull off and I do't want to force them.
Re: Ignition coil removal
« Reply #1 on: August 07, 2018, 12:09:14 PM »
PULL straight up.   They are a tight fit.
Lost again
Offline The Reaper
  • Bike: 800 XRX
« Reply #2 on: August 07, 2018, 12:32:50 PM »
Have done that, they aren't budging, and my knuckles are bloody from trying! I have decided to leave them until the next service as it's only a spark plug check. Next service is the 24k one will be done at a garage who will have more knowledge than me.
« Reply #3 on: August 07, 2018, 12:46:22 PM »
Disconnect the low voltage lead then pull and twist.  If they aren't budging then at least there is a good seal!!
Lost again
Offline mcinlb
  • Bike: 2018 Tiger 800
« Reply #4 on: August 07, 2018, 03:19:28 PM »
Offline The Reaper
  • Bike: 800 XRX
« Reply #5 on: August 08, 2018, 09:09:26 PM »
Definitely a good seal, tried all that couldn't get any of them to budge! I'm no muscle man but I'm not that weak!
It's a shame as everything else went really smoothly, including tank, airbox and rear wheel removal!
Offline The Reaper
  • Bike: 800 XRX
« Reply #6 on: August 08, 2018, 09:13:05 PM »
Cheers, will order one ready for next time!
Offline SimonF59
  • Not happy, not sad just grumpy 😊
  • Bike: 800XRX
« Reply #7 on: March 15, 2020, 12:13:31 PM »
 :493: just the answer I needed. Seems to me they have never been off on my 32,000 mile machine. Although LINGS of Norfolk and Suffolk have been servicing it up 30,000 miles.
Still wondering how......
Offline tigerman1960
  • Bike: tiger800 XCA
« Reply #8 on: March 15, 2020, 08:19:53 PM »
i find the best way is to try and spray some WD40 down the side of the coil packs while turning them, then leave for about 10 minutes, i then get a long flat tyre lever and put the tyre lever under the plug part of the coil pack, slide the tyre lever forward until you can lift the lever up ( hope this makes sense to you ) and prise the coil out, i always think it will snap but it never has, and i have done it on 4 tigers now, lots of times with no problems, it does need to be done with steady force, no jerky movements.
Offline posty
  • Posty
  • Bike: Tiger 800 XRX 16
« Reply #9 on: March 20, 2020, 11:33:28 AM »
Bit agricultural but when I had same problem, I carefully pulled them out using a water pump pliers to grip them - should have used some masking tape I suppose but it workd anyway
