Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Diagnostic  (Read 1029 times)
Offline Seanocaoimh
Diagnostic
« on: August 13, 2018, 04:30:44 PM »
Lads,
 I have dealertool and I find it a good product , after the little bit of bother at startup. I'm thinking of getting another tool to get more of a complete service/maintenance. Don't quite know which one to go for?, some are free some you have to purchase.Any advice appreciated.
Online UncleGary
Re: Diagnostic
« Reply #1 on: August 13, 2018, 09:21:01 PM »
Are there features that you are looking for that aren't part of TigerTool or DealerTool? There is a lot of detailed information on this site for those two applications. The application that the Triumph dealer uses can access more information but is quite expensive.
Re: Diagnostic
« Reply #2 on: August 14, 2018, 06:22:30 PM »
There's TigerTool, Dealertool and Tuneecu (Not for post 15)
Dealertool has no real advantage over Tigertool and costs
Tuneecu, if you can use it - as in pre 15, allows fiddling on a grand scale.  I have only turned off the O2 sensor and lowered the fan on temperature (from 103 to 99)
Offline Seanocaoimh
Re: Diagnostic
« Reply #3 on: August 14, 2018, 08:57:08 PM »
KildareMan! When you say, TuneECU if you can use it ? Do you mean you need to be very competent on computers. I would like to be able  to change some settings, like you did yourself?
Re: Diagnostic
« Reply #4 on: August 14, 2018, 09:02:00 PM »
You need to be pre 15 model, or 1st generation. After that the ECU is locked.
Offline Seanocaoimh
Re: Diagnostic
« Reply #5 on: August 14, 2018, 10:03:40 PM »
Ya I have a 2013 roadie.is it a complicated  procedure to download tuneecu.
Re: Diagnostic
« Reply #6 on: August 15, 2018, 06:27:23 AM »
*Originally Posted by Seanocaoimh [+]
no, easy as...
http://www.tuneecu.com/TuneECU_En/links.html
Offline andreiu
Re: Diagnostic
« Reply #7 on: August 19, 2018, 10:13:33 PM »
Hi.i am searching for tigertool everywere and i dont fint it.Can anydody help me please.Thank you
Re: Diagnostic
« Reply #8 on: August 19, 2018, 10:35:46 PM »
 :401:
Just put one word Tigertool in the search box and you would have got the answer.
https://www.tiger800.co.uk/index.php/topic,24213.0.html
Offline andreiu
Re: Diagnostic
« Reply #9 on: August 19, 2018, 11:20:37 PM »
:401:
Hi.I might be blind or something like that.I have used the search box alot of time,i did find the post,but the adjust file no.Thank you once again
