Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Save weight  (Read 3816 times)
Offline sezian
Re: Save weight
« Reply #40 on: September 25, 2018, 07:12:11 AM »
How much does a standard battery weigh? I wouldn't have thought it was anywhere near 4.4kg  :187:
Re: Save weight
« Reply #41 on: September 25, 2018, 08:58:14 AM »
Didn't think so either but then I checked.
 YTX16-BS 12V 14AH is (drum roll please):
Brand: Yuasa
Voltage : 12 V
Capacity : 14 Ah
Cold start performance: 220 EN
Dimensions : 150mm x 87mm x 161mm
Weight (filled) : 4.8kg
Maximum charge rate: 1 Amp
Terminal layout: Left: + Right: - (With the terminals on the edge nearest to you)
Type : AGM battery
Having found that I very much doubt a replacement Li-Ion is going to be just 400 grams
 Manufacturer's Part Number LFX21A6-BS12
Part Number SBT-LFX21A6-BS12
UPC 4897034420692
Battery Usage Starting
Volts 12 V
Battery Terminals Top and side
Battery Type Lithium
Cranking Amps (32 degrees F) 315 amps
Length (in) 5.830 in.
Width (in) 3.230 in.
Height (in) 5.510 in.
Weight 3.030 lbs. - that's 1.37 Kg
Quantity Sold individually.
Notes Amp hour capacity is 21
Re: Save weight
« Reply #42 on: September 25, 2018, 03:57:48 PM »
Blow 2K on a pair of carbon wheels.
That'd be the best weight saving you ever do, it's like someone halved the weight of the bike.
Offline Radzz
  • Bike: White 800XC
Re: Save weight
« Reply #43 on: September 25, 2018, 04:12:03 PM »
Brand: Yuasa
Voltage : 12 V
Capacity : 14 Ah
Type : AGM battery
UPC 4897034420692
Volts 12 V
Blimey thats about 3kgs... not bad really :002:
Offline Dick
  • Bike: tiger 800xR
Re: Save weight
« Reply #44 on: September 25, 2018, 04:56:37 PM »
My battery is a Yuasa 16 5.170 k not a 14 so have saved 4.4k I'd love a pair of mag wheels, one of the reasons I did not go for a xc was the weight of the wheels,
just because you have your eyes open does not mean you are alive!
Re: Save weight
« Reply #45 on: September 25, 2018, 04:58:36 PM »
*Originally Posted by Dick [+]
Not mag, carbon FTW  :017:
Offline Dick
  • Bike: tiger 800xR
Re: Save weight
« Reply #46 on: September 25, 2018, 06:51:12 PM »
Your right my mistake ,I've set fire to a mag wheel ! Fun,
Offline Dick
  • Bike: tiger 800xR
Re: Save weight
« Reply #47 on: October 02, 2018, 11:19:52 PM »
I give up! My .75k battery has gone flat 11.5 v! Shido
Tx12-bs lion 12v 42wh.I did 100 miles around Cotswolds ok ,inc heated grips,  But 3 days of not running  ,on good,back to led ,Fitted a Smaller 14 4.7k battery ,what was in the bike was  a 16 5.4 k)
Online healdem
  • ....has a fluffy tube
  • Bike: 2011 Tiger 800
Re: Save weight
« Reply #48 on: October 03, 2018, 08:46:48 AM »
So it sounds like the replacement battery did not accept charging. I hope you haven't affected the rest of the electrical system.
On the plus side having reduced the bikes overall weight, it must be easier to push the bike around  :492:
Offline Bladerunner99
  • Bike: 2018 XCA
Re: Save weight
« Reply #49 on: October 03, 2018, 12:58:42 PM »
There you go, you've lost another few pounds!  :492:
Ride to work. Work to ride
