Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Replace bearings fron wheel , how?  (Read 1594 times)
Offline Rorut
  • Bike: Tiger 800 XC
« on: September 14, 2018, 02:38:29 PM »
How do I change them? They are totally stuck on borh sides.
Offline Alunr
  • Alun
Re: Replace bearings fron wheel , how?
« Reply #1 on: September 14, 2018, 03:25:12 PM »
Have you checked this out?
You're never too old to have a happy childhood :-)
Past Bikes: Panther 600, BSA Bantam, Lambretta TV 175, Lambretta GT200, AJS 125, Suzuki Gladius, Honda NT700. Present: Triumph Tiger 800 ABS
Offline Rorut
« Reply #2 on: September 14, 2018, 04:55:06 PM »
Its like a pipe in between the bearings. Cant get in and hit the bearing from behind
And both bearings are totally stuck. Is this normal? Bought the wheels used.
Sprayed with wd40 and it got colored brown from what I guess is rust. The rear wheel seems to be fine
« Last Edit: September 14, 2018, 04:56:48 PM by Rorut »
Offline Admin
  • Administrator
« Reply #3 on: September 14, 2018, 05:11:34 PM »
Wheel bearing puller.
Various types available, should find one on ebay or Amazon.
Need Support ? Post issues in this section: Forum Help / Issues / Problems
Alternatively, pm me about private or commercial issues/questions.
Offline Rorut
« Reply #4 on: September 14, 2018, 09:52:42 PM »
What kind of puller? The ones that expand in the bearing and uses a slide hammer?
Where can i buy a good bearing kit? Triumph wants about 70 for bearings, seals and circlip, a bit pricey? SKF would be nice
Offline odum666
« Reply #5 on: September 15, 2018, 08:27:22 AM »
Do you know anyone with a welder. Drop a long bolt through the bearings. Weld the head to one bearing and tap it from the other side
when you sit on a sports bike you feel special...when you sit on an adventure bike you feel something special is going to happen!!
Offline Cats
  • Bike: 800XC
« Reply #6 on: September 15, 2018, 08:54:56 AM »
Tiger 800. There's no effing need for it.
Gnats cock
Offline gordybrock
  • Bike: Tiger 800XR 2012
« Reply #7 on: September 15, 2018, 08:56:07 AM »
*Originally Posted by Rorut [+]
...Where can i buy a good bearing kit? Triumph wants about 70 for bearings, seals and circlip, a bit pricey? SKF would be nice
I had my front wheel bearings renewed a few weeks ago, mechanic said some previous idiot owner/dealer must have used a pressure washer around the wheel, bearing on one side rusty and stuck fast. He struggled to get them out and eventually had to weld a bolt across the bearing case and managed to knock them out. I sourced the bearings (SKF) and seals myself from my local bearing factor...14 for the set. No need to pay Triumph's outrageous prices.
I'm from Wigan Me
Offline Rorut
« Reply #8 on: September 15, 2018, 01:12:15 PM »
I heated hub and used a slide hammer with a puller, very easy to get them out that way (5min job).
Here is one bearing, cant be moved at all
I can not find the sealing 35 47 6/65
Only 35 47 6. What is the last numbers for? 6 , 6/65
Online CB250G5
« Reply #9 on: September 15, 2018, 04:58:02 PM »
35 is the ID, 47 is the OD and 6 would be the width.  Not seen a 6/65, before, give it a measure, maybe it's supposed to fill either a 6 or 6.5 mm width.  In any case, you should get one easily enough.  I see Simply Bearings have them at 6mm from 2.12 upwards.
2015 Tiger 800 XRx, Yamaha RD350YPVS special, Yamaha TDR250 (being rebuilt), Yamaha SRX400 Super Single and a Voskhod 175
