Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Single locking barrel  (Read 738 times)
Offline Guyver
« on: September 14, 2018, 03:32:42 PM »
After a single locking barrel for my topbox. Needs to be untouched so I can get it set to my keys.
Offline Moosehead
  • Bike: 2011 Orange XC
Re: Single locking barrel
« Reply #1 on: September 16, 2018, 07:38:49 AM »
Are you after a pre keyed lock? I had to buy a set of 3 and I think I still have 1 spare, however it is already keyed to a lock??
Dan
Offline Guyver
« Reply #2 on: September 16, 2018, 10:10:22 AM »
*Originally Posted by Moosehead [+]
Dan
Hi Dan, I've just ordered 3 from Fowler's. I'll get the 1 made to work and keep the others as spares incase anyone else is stuck.
Thanks for the offer though mate  :028:
Offline Gavspad
« Reply #3 on: December 03, 2018, 08:30:12 PM »
Ive just purchased a 2015 XRX and only has 2 barrels for luggage - who do you get to adjust the spare ones your buying?
Gavin
« Reply #4 on: December 03, 2018, 09:04:52 PM »
You can actually do it your self if you don't mind disassembling the lock and reordering the bits inside it.
Offline Gavspad
« Reply #5 on: December 03, 2018, 09:16:12 PM »
I can put bodies back together - but not so good with fiddly mechanical bits. Less patience if it doesnt have a heartbeat. Im good at demolishing stuff though 🤦🏻‍♂️
Offline Guyver
« Reply #6 on: December 04, 2018, 04:06:40 AM »
*Originally Posted by Gavspad [+]
This is what Triumph do.
Put your key into the lock, then using a needle file, smooth down the pins that are now sticking up. They don't have to be pretty, just flush with the locking barrel.
That's all Triumph do and charge an hour's labour.
No messing about removing bits that you could lose.
Gavin
Offline Gavspad
« Reply #7 on: December 04, 2018, 07:48:31 PM »
Thanks Guyver. Will see if I can find any YouTube tips
Offline Guyver
« Reply #8 on: December 04, 2018, 10:25:11 PM »
I'll try and quote properly this time. It's dead easy. Needle files are cheap enough and the pins are soft so won't take much filing down. Take your time and it should be done in less than 5 minutes 👍
