Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Triumph Tiger 800 Forum
Tiger 800xc preload tension adjuster wrecked?
16 Aug 22, 23:49 pm
1
2
Go Down
Author
Tiger 800xc preload tension adjuster wrecked? (Read 4578 times)
Parkside kid
Tiger Cub ‐
1
Topic Author
Parkside kid
Tiger Cub
Topic Author
Bike/Model: Tiger 800xc 2011
on:
Sep 22, 2018, 08.13 pm
Hi All. New to this forum having recently bought my first tiger 800xc.
I tried to adjust the preload today and found the adjuster was seized solid. After a using gallons of WD40 and endless wiggling I managed to free it up and get it moving nicely. The flat head tip of the adjuster had been trashed by previous owner trying to do the same thing (I guess).
Upon further investigation I found a bump at the rear of the preload adjuster.
It looks as though the ball bearing which I assume gives the ‘click’ when adjusting has tried to burst through the casing.
I’ve attached some pics here.
Anyone ever seen/done this before?
Is this likely to have been caused by heavy off road use/drop off/jump etc?
Cheers!
CSAW
Tiger Master ‐
782
#1
CSAW
Tiger Master
Bike/Model: 2012 Blk XC ABS
Re: Tiger 800xc preload tension adjuster wrecked?
Reply #1 on:
Sep 22, 2018, 08.28 pm
Spraying some WD40 or some other lubricant in where the detent balls are is good measure. My adjuster has become hard to turn on several occasions. I don't think it would really matter if the detents didn't work as there is a lot of pressure on the adjuster and imagine it wouldn't move anyway. If you want to take the black plastic detent cover off I believe it has left handed threads, the best I remember.
chuckxc
Tiger Jedi ‐
1207
#2
chuckxc
Tiger Jedi
Bike/Model: 12XC, 18XCX
Country:
Reply #2 on:
Sep 22, 2018, 10.19 pm
Deep-six the detents, I did. They just deteriorate and you don't need them anyway, just count turns from one limit to the other (20 from memory?) then use this to work out your setting.
Also (from memory 10mm or 8mm nut?) you can use a socket wrench instead of the flat-blade screwdriver.
Dick
Tiger Pro ‐
158
#3
Dick
Tiger Pro
Bike/Model: tiger 800xR
Reply #3 on:
Sep 26, 2018, 09.16 pm
See my post on pre load under( miss technical help required) get a knob!
CrazyL
Tiger Member ‐
63
#4
CrazyL
Tiger Member
Reply #4 on:
Sep 27, 2018, 08.59 pm
I unseized mine the other day
I used an 8mm socket on the end of a 21" breaker bar, and some gentle nudging. There are 10 clicks, according to my shock. Glad I got it moving, was thinking I might have to give Nitron some more of my money
Also, unlike yourself, I was lucky and after a bit of GT85 and moving to and thro, it turns and clicks.
Crazy L, The Original since 1976
Guyver
Tiger Master ‐
684
#5
Guyver
Tiger Master
Bike/Model: Tiger 800XC
Country:
Reply #5 on:
Oct 04, 2018, 02.16 pm
Search eBay for an adjustment handle. Believe they were made by a guy on here originally. They sit over the hex part and clamp on with 3 grub screws. Then once a month you can turn it up and down with the handle and it's super easy.
KildareMan
Tiger Jedi ‐
9018
#6
KildareMan
Tiger Jedi
Bike/Model: Moto Guzzi V7850
Country:
Reply #6 on:
Oct 04, 2018, 04.25 pm
Originally Posted by
Guyver
PaulVFR
Moto Guzzi V7 Centenario baby!
mercucio1
Tiger Cub ‐
11
#7
mercucio1
Tiger Cub
Bike/Model: Tiger 800 XC
Reply #7 on:
May 01, 2020, 08.48 am
CrazyL
My spring preload adjuster is jammed as well. Used plenty of WD40 and still nothing. I am planning to use 8mm wrench with breaker bar as you, so is it better to do it when someone is sitting on the bike (compressed suspension) or not? Which direction is better to break it clockwise (harder) or counterclockwise (softer)? I hope nothing gonna break
Guyver
Tiger Master ‐
684
#8
Guyver
Tiger Master
Country:
Reply #8 on:
May 01, 2020, 09.18 am
Loads of WD-40 like you've already used and gentle turning side to side on the adjuster but. If it's stops moving, plenty more WD-40 and try again.
mercucio1
Tiger Cub ‐
11
#9
mercucio1
Tiger Cub
Reply #9 on:
May 01, 2020, 09.25 am
Will do ... cheers mate
1
2
Go Up
New
New Members
Stevie.P
Today
at 11:13 pm
First Tiger 800!
New Members
Stevie.P
Today
at 11:11 pm
no power to auxiliary sockets
ped
Today
at 08:09 pm
Tiger 900 items for sale
For Sale
Dizzy
Today
at 07:44 pm
Bad oil
Paulhere
Today
at 06:17 pm
TEKMOUNT for GPS
Sat Navs, Intercoms, Cameras, and other tech gadgets
Derchef1962
Today
at 04:44 pm
What do y'all use for tank bags?
Derchef1962
Today
at 04:37 pm
How To Use TigerTool V3.3 Service Utility Software
"How To" Technical Articles
eskalextric
Today
at 11:37 am
Buy a rear sprocket from...?
Ben_snapper
Today
at 11:22 am
*** SOLD *** Tiger 800 - hand guard and brake lever
For Sale
grunty-motor
Today
at 09:14 am
