Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Spanner Symbol on clocks  (Read 1656 times)
Offline pennpeel
  • Bike: Triumph 800 xc
« on: October 08, 2018, 07:39:30 PM »
recently the spanner symbol has appeared on my XC clocks.  I presume its service interval message.  I've never seen it before, normally get my bike serviced at a independent garage.  Do they need a special tool to reset it?  Its not really annoying but if its easy to turn off I'll it off. Thanks in advance
Offline UncleGary
Re: Spanner Symbol on clocks
« Reply #1 on: October 08, 2018, 09:25:48 PM »
Do a search on this forum. Programs like Dealer Tool can handle it and are very modestly priced. I know of no way to disable the "wrench" icon. Maybe the dealer can do it but the cost would be substantially more than the software and cable cost.
Online T800XC
  • Bike: 800XC & Explorer
« Reply #2 on: October 08, 2018, 09:56:45 PM »
You can also do it for free yourself using TigerTool or TuneECU.
See here for TigerTool...
https://www.tiger800.co.uk/index.php/topic,24213.0.html
Offline RoadWarrior
  • Ex Member
« Reply #3 on: October 13, 2018, 09:20:13 AM »
+1
Offline pennpeel
« Reply #4 on: October 13, 2018, 05:06:38 PM »
ok thanks all i'll look into it
Offline coddy
« Reply #5 on: December 11, 2018, 08:41:51 PM »
Any luck removing the spanner icon? My battery drained flat on my bike and after charging it up again the display now constantly shows the spanner symbol and on start up says my service is due that day which is annoying as it clearly isn't due for months or about 4000 miles.
« Reply #6 on: December 11, 2018, 11:10:26 PM »
The same tab in Tigertool that resers the 'service spanner' also allows you to alter the service mileage, you would simply reset the figure to 6k minus what you have done since last service (if 6k is what you want).  :028:
Offline coddy
« Reply #7 on: December 12, 2018, 10:43:25 PM »
Thanks Stevie  :038:
Offline Blue Flame
  • Bike: Tiger 800XRT
« Reply #8 on: January 19, 2019, 10:40:02 AM »
Hiya
Just wanted to add to this to say that I had this issue when I disconnected the battery to fit some additional wiring when I got the bike last month.
I found that the date and time had to be reset to the correct date and time and this cleared the spanner symbol.
« Reply #9 on: January 19, 2019, 12:27:03 PM »
*Originally Posted by Blue Flame [+]
Hiya
Strange, reset the clock yes, but never had disconnecting the battery for 'short periods' cause the service spanner to come on. Only a few days ago I had the battery disconnected to fit my heated clothing power leads . just the clock needed to be reset. :027:
