Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Brake discs and abs ring  (Read 1658 times)
Offline Bikerjimbob
  • Bike: Tiger 800xca
« on: October 13, 2018, 07:14:21 AM »
Hi all,
Looking for a bit of confirmation here, am i right in saying the front brake discs are the same for every 800 model no matter what year? Part number PFKL2044675
Also the ABS ring PFKL2037132
As in will a 2014 disc fit a 2016 bike ?
I have looked on worldoftriumph and thats how it looks to me
Cheers Jim
Re: Brake discs and abs ring
« Reply #1 on: October 13, 2018, 08:37:20 AM »
Yeah, IIRC they're all the same
Galfer list the same discs for all models
Offline Bikerjimbob
« Reply #2 on: October 13, 2018, 10:43:34 AM »
Thanks mate I was hoping I was right  :028: got a chance of some as new ones and thought they are handy spares.
Cheers Jim
Offline Rorut
  • Bike: Tiger 800 XC
« Reply #3 on: October 14, 2018, 03:51:45 PM »
Im converting to roadie wheels on my xc. I noticed a difference where the abs ring is.
On my spoked wheels the abs ring surface is flat with the hub but on my roadie wheel the ring is a bit above the hub edge. Is this going to interfere with the sensor?
Anyone with roadie wheels that compare with my image?
« Reply #4 on: October 14, 2018, 04:48:22 PM »
Is the sensor adjustable?
If so just set it to spec.
Offline Rorut
« Reply #5 on: October 14, 2018, 04:58:29 PM »
I dont know. First time removing the wheel. I will check that
Offline Rorut
« Reply #6 on: October 14, 2018, 06:49:53 PM »
Looks like I maybe need some shims :)
Offline Bikerjimbob
« Reply #7 on: October 14, 2018, 08:43:11 PM »
Might be worth talking to Troop as he has just successfully completed the conversion with no problems whatsoever.
Re: XCx > 19"/tubeless conversion
Reply #18 on: October 09, 2018, 02:43:23 PM
Quote
Just completed my XCx wheel conversion to 17"/19" cast wheels from XR models. Zero fitment issues and all works well. Using a 100/90-19 front tire, my ride height only decreased by approx .5". Not going to bother with lowering links. I like it :)
« Reply #8 on: October 14, 2018, 09:00:04 PM »
It is as simple as the manual shows. Just measure the gap and correct if out of spec. (I used an ordinary flat washer instead of the 'shim' to increase the gap on my rear sensor). :028:
Offline herdygerdy
  • Bike: 17 White XRT
« Reply #9 on: October 15, 2018, 08:21:58 AM »
*Originally Posted by Bikerjimbob [+]
Sounds like a great mod Jim, very confidence boosting kerbside and at low speed I am sure.
I was initially a bit anxious about the 810 mm seat height on my XRT (I'm 5' 6"), but after a coupla' thousand kays on the clock now, 'Teddy' seems to have 'settled' into his suspenders and I am very pleased I didn't go for the LRH model.  I''m more confident on the XRT than I ever was on my now departed '07 Wee Strom, and it even had a lowered seat...
