Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Undo brake pad bolt?  (Read 1069 times)
Offline Rorut
  • Bike: Tiger 800 XC
« on: October 16, 2018, 09:12:20 AM »
It is stuck, cant get it out... any ideas
Why did they not use a torx or anything better than using a flat screwdriver
Re: Undo brake pad bolt?
« Reply #1 on: October 16, 2018, 09:18:35 AM »
*Originally Posted by Rorut [+]
Search the site.  Numerous threads already on the subject.  You'll get sick of reading about the pluses and minuses of copperslip / where to apply and not apply.  You'll also learn of PaulVFR stainless pins.
Get as big a Torx as will fit into the hex head, or slightly bigger.  Hammer it in and remove pin.  Works a lot of the time.
Offline Rorut
« Reply #2 on: October 16, 2018, 12:16:50 PM »
Problems is there is no hex head it is made for a flat screw driver...
« Reply #3 on: October 16, 2018, 12:36:22 PM »
Ahh the cover.  Shite aren't they.  A punch and a hammer - near the outer edge at an angle and tap it out.  Cover will be fecked so bin.
Offline Rorut
« Reply #4 on: October 16, 2018, 12:42:37 PM »
Im talking about this bolt
Offline Grumps
  • Bike: 2018 800 Xca
« Reply #5 on: October 16, 2018, 01:08:01 PM »
iirc THE SCREWDRIVER HEAD IS FOR A SHORT COVER AND THE HEX HEADED BOLT IS UNDERNEATH. tWO THINGS TO UNDO
..sorry...caps lock on
2018 Xca. BMW K1600GTL. Suzuki GT380
Offline JMc
  • Bike: tiger800
« Reply #6 on: October 16, 2018, 01:10:29 PM »
the bit with the flat screw driver head is just a grub screw, short to prevent the pin from undoing and coming out, remove this 1st, then you will need a allen head to remove the pin your other arrow points to.
Jmc
« Reply #7 on: October 16, 2018, 01:28:23 PM »
Re-attach the calliper, then get a big LONG flat blade driver that is a good fit in the slot of that grub screw.
I always use my longest drivers to undo, get more force on the job, with some torque reaction, less chance of chewing up the slot. Tighten with normal driver. To each his own on this method, always worked for me.
Offline Rorut
« Reply #8 on: October 16, 2018, 01:41:54 PM »
Thanks a lot! Did not know. Im going to swap between wheels. Is loctite really important on the bolt when refitting it?
« Last Edit: October 16, 2018, 02:00:50 PM by Rorut »
« Reply #9 on: October 16, 2018, 01:46:06 PM »
Thanks a lot! Did not know. Im going to swap between wheels. Are loctite really important on the bolt when refitting it?
NO! Do not use anything other than, imo a dab of copper slip.
