Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Unifilter prefilter  (Read 1502 times)
Online Q
  • Bike: 800 XCA
Re: Unifilter prefilter
« Reply #10 on: June 08, 2020, 04:23:04 PM »
I fitted my T800 Xcx from 2016 with a unifilter pre-filter, ordered directly from them in Australia.
Merci beaucoup - will have to do that but with our weak currency, along with the postage and duties to South Africa, this is going to be a very expensive filter :-)
Online Q
  • Bike: 800 XCA
« Reply #11 on: June 08, 2020, 05:29:52 PM »
k - instant gratification is bad news
whipped-out the credit card and ordered two from Oz
better than damaging the engine and after spending the day cleaning the bike and kit after the weekend's run in the dirt, I realised that in the prolonged drought conditions that we are currently in, dust is going to be a major factor on the rides over the next few months - thus better safe than sorry
Offline XYooper906
  • Bike: 2012 Tiger 800XC
« Reply #12 on: June 09, 2020, 09:49:16 PM »
*Originally Posted by Q [+]
Some advice pse - will this work on a 2019 800 XCA?
I can tell you with certainty that the older design airboxes have an opening with flat sides on top and bottom. The NU-3704 rubber flange is designed to fit that hole.  I had been using the older design NU-3704 filter on my 2012 XC, until it developed several worn spots and holes. I ordered the newer design AU-3705 and then modified my airbox with a round hole to fit it. The new filter has a slightly thicker foam and has less contact with the adjacent items, so I'm hoping that it will outlast the older one.
Online Q
  • Bike: 800 XCA
« Reply #13 on: June 10, 2020, 06:52:55 AM »
*Originally Posted by XYooper906 [+]
tks very much for your response - as above, I spent the money to get filters from Oz - with the state of the world at present, it might, however, be sometime before I actually receive them
