Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: New Triumph Speed Twin 1200  (Read 1888 times)
Re: New Triumph Speed Twin 1200
« Reply #20 on: January 29, 2019, 09:01:49 AM »
Fettle the tumblers? Forgive me but I haven't got a clue what you're talking about...
When older Yam ignition switches get a bit stiff, the key doesn't turn easy, you have to push it forward to turn it, Kwak are pull back, the tumblers are worn. A cure (bodge) is to strip the switch & trim the tumblers to suit, dab of grease & refit. You can continue to push/pull the key but one day it might not work. Likely cause is they were assembled dry. The proper cure is obviously a new ignition switch. My 25 year old grey import traillie gets fettled best I can, spares are not easily obtainable.
« Reply #21 on: January 29, 2019, 01:39:33 PM »
Have we had this vid.
« Last Edit: January 29, 2019, 01:45:21 PM by Paulhere »
