Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
March 06, 2021, 01:51:39 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
XRt cuts out
Print
Pages:
1
2
3
4
11
Go Down
Author
Topic: XRt cuts out (Read 18674 times)
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Re: XRt cuts out
Reply #10 on:
December 21, 2018, 09:16:30 PM »
Originally Posted by
walt
update on this
dealer picked my bike up yesterday, rang me later in the day to say they found faulty Inlet air temperature sensor, they fitted new one and delivered bike back to me today, will try it out over next couple of days and report back....
Thanks for the update.
Would have thought if the IAT sensor was faulty an error code would have come up on the engine fault light indicator. But maybe it was just reporting incorrect temperatures. If so, that wouldn't necessarily show as an error code.
Logged
walt
Tiger Master
Re: XRt cuts out
Reply #11 on:
December 21, 2018, 10:02:52 PM »
chuckxc
exactly, dealer gave me a print out of before and after new sensor fitted, no fault codes, but different/incorrect temps showing....
Last Edit: December 21, 2018, 10:46:54 PM by walt
Logged
Bladerunner99
Tiger Master
Bike: 2018 XCA
Re: XRt cuts out
Reply #12 on:
December 22, 2018, 12:59:38 AM »
Please excuse my ignorance. Could someone please explain how the IAT sensor would cause the bike to cut out intermittently, would it not cut our or at least fail to start on a regular basis if it was faulty?
Logged
Ride to work. Work to ride
mcinlb
Tiger Master
Bike: 2020 Tiger 900GT
Re: XRt cuts out
Reply #13 on:
December 22, 2018, 09:15:03 AM »
Does sound a bit "ifffy" to me, my Xrx is show what looks like correct temps on the dash so not sure how it would effect fuelling unless it was miles off and causing poor fuelling
Logged
walt
Tiger Master
Re: XRt cuts out
Reply #14 on:
December 22, 2018, 04:59:34 PM »
well, i'm not 100% convinced yet....until ive had a decent ride on it....the other symptom was rough throttle response just off tickover, depending which way the faulty IAT sensor readings differed, it could have been running weak.....that's how it felt at the throttle, it usually cut out on a closed throttle at slowish speed, coming up to a roundabout while dropping down from 3rd to 2nd....of course it could have been cutting out between 6-5 and 5-4, but the bike was carrying enough speed for it to bump start without me noticing...I suppose if it was running weak, it would be most vulnerable to cutting out on small throttle openings, probably run ok rest of time (which it did)
and of course, i'm not saying its fixed, havn't had a decent ride on it yet, so it may have the same problem, but changing the IAT sensor has made the low throttle response less erratic (in the garage at least)
and also, does that mean that the people who have the same identical symptoms as my bike all have a faulty IAT sensor....I doubt it..
mcinlb
engine temp gauge reads coolant temp, not the same as Inlet air temp, ECU probably uses IAT signal as one of a number of signals to calculate fuelling...
Last Edit: December 22, 2018, 05:02:52 PM by walt
Logged
midnight
Tiger Cub
Re: XRt cuts out
Reply #15 on:
December 22, 2018, 05:29:01 PM »
Hello from Denmark. Had my 2018 xrt cutting out about 15-20 times during the first 10.000 km. After service 10k there has been 0. Therefore I think the 10.000 map has dealt with the problem. Has pt. 16.500 km on the clock, and no cut outs since last service!!!
Logged
walt
Tiger Master
Re: XRt cuts out
Reply #16 on:
December 22, 2018, 07:44:22 PM »
midnight
thanks for info....hope mine is ok now...
Logged
K1W1
Tiger Jedi
Bike: XRX
Re: XRt cuts out
Reply #17 on:
December 22, 2018, 10:42:18 PM »
walt
If it is the IAT sensor then yes it is highly likely others have the same problem with the same sensor because it is likely to be a batch issue with a bunch of sensors made by whoever supplies them to Triumph.
Logged
walt
Tiger Master
Re: XRt cuts out
Reply #18 on:
December 23, 2018, 02:01:47 AM »
K1W1
be interesting to see if that's the case......i'll try a hundred miles or so on mine and see if its cured....
Logged
pme
Tiger Member
Bike: xrx lrh 2018
Re: XRt cuts out
Reply #19 on:
January 02, 2019, 03:56:11 PM »
Midnight, did they carry out a remap or was a part changed, otherwise why has it stopped being an issue?????
thanks
pme
Logged
Print
Pages:
1
2
3
4
11
Go Up
XRt cuts out
TPMS
Tyres and Wheels
T800XC
Today
at 01:22:04 PM
Happy new bike day
norboy
Today
at 01:09:13 PM
Touratech Small windscreen
Accessories and Products
samsgrandad
Today
at 12:17:09 PM
Engine management light on after dead battery
Stevie.P
Today
at 10:42:35 AM
return to triumph
New Members
Whoa
Today
at 07:55:59 AM
Happy Birthday x10
PapaTom
Today
at 07:27:32 AM
2016 800XRt - Removing Throttle Restriction?
ECU Re-Mapping and Tuning
paul_o
Yesterday
at 09:58:00 PM
Problems with fork removal
pennpeel
Yesterday
at 06:03:47 PM
Hello!
New Members
Tigermainia
Yesterday
at 06:00:58 PM
Multimeter Recommendations
AvgBear
Yesterday
at 04:55:01 PM
