Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
January 16, 2021, 11:12:37 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
XRt cuts out
Print
Pages:
1
2
3
4
5
11
Go Down
Author
Topic: XRt cuts out (Read 17937 times)
midnight
Tiger Cub
Re: XRt cuts out
Reply #20 on:
January 02, 2019, 04:33:29 PM »
No. Nothing changed. Only a regular service and a new mapping, which was scheduled acording to my mecanik. He said, he would report back to Triumph, that it probably solvede the issue. I have had no "hickups" since.
Logged
ColinXCX
Tiger Pro
Bike: 2017 Tiger XCX
Re: XRt cuts out
Reply #21 on:
January 02, 2019, 07:16:06 PM »
With regards to the remap, is that normal procedure after certain mileage of is it just for the 2018 models? Thanks
Logged
grizzlybear
Tiger Jedi
Bike: tiger 800Xr
Re: XRt cuts out
Reply #22 on:
January 03, 2019, 01:37:20 PM »
It normal for all car and bike manufacturers to update the ECU.
Logged
Safe Riding
Dave( Grizzlybear) honda 125T, Z650C2, GPZ750, GTR1000, VX800, VN1500 ,2013 tiger800,2018 Tiger800Xr, CG125 and loads of C90`s :)
Stevie.P
Tiger Jedi
'Arte et Marte'
Bike: 2015 Tiger XRt
Re: XRt cuts out
Reply #23 on:
January 03, 2019, 02:47:53 PM »
Originally Posted by
ColinXCX
grizzlybear
Updates are effectively correcting errors and/or adding improvements to the ECU programming. If there are no current reported issues, like cutting out, or a flat spot in fuelling, etc. that have been rectified then there would be no update. I know my XRt ECU was updated as part of 6k service and rectified the occasional stalling on downchange to 2nd gear.
This Tigertool pic showed 'Tune' date recorded as loaded (not when released) on 6k service date (17/10/16) and as this was taken 18/05/18, diagnosing a fault, also indicates no update was applied at the 12k service 29/08/17:
I have just been out and quickly run Tigertool and the details are the same as above, so based on the fact that the dealer is supposed to plug in and check (and update if applicable) chassis ECM and engine ECM on every service then, provided they did do it, then there has been no ECU update (unless post 11/09/18 18k service) since pre-Oct 16 (unless someone with a 2nd gen Tiger has a, presumably, higher numbered 'Tune No.' than above.
Logged
midnight
Tiger Cub
Re: XRt cuts out
Reply #24 on:
January 03, 2019, 03:29:32 PM »
Just too be sure, we are talking about the same bike, mine is the new 2018 xrt. Maybe the mapping is different??
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Re: XRt cuts out
Reply #25 on:
January 03, 2019, 04:17:37 PM »
The mapping for the 'gen 3 2018 on' Tiger is probably different to mine (2015-2017 gen 2) but the same criteria as I described would apply regarding updates. When you put your bike in for 'official' servicing Triumph will update your bike if there is an update applicable. It is quite likely at the 12month/6k service of most 'new' models that there will be an initial update to correct any minor issues, but given that the 'gen 3' mechanically is only a tweaked 'gen 2' I wouldn't expect too many issues to update.
Logged
xc dave
Tiger Pro
Bike: 800XC + 2 OTHERS
Re: XRt cuts out
Reply #26 on:
January 04, 2019, 06:14:30 PM »
I spoke to Triumphs Peter Clarke at the NEC and he knew very little about the problem, so I have to ask are dealers contacting Triumph to report the fault.
If anyone is not happy and their bike is still suffering from this stalling problem then contact Peter Clarke on: 0116 215 1150.
This is not a direct line to Peter so you will have to ask to speak to him.
Logged
roy.c
Tiger Member
Bike: tiger 800XC
Re: XRt cuts out
Reply #27 on:
January 09, 2019, 04:59:12 PM »
Not sure if I had the same problem but my 2013 XC suddenly started cutting out when on the over-run, eg approaching a junction and throttling back. Sometimes even cutting out between gear changes.
I spoke to my dealer who suggested it was caused by having turned off the engine while still having the throttle open.
The cure was to force the ecu to re-set - this involved simply starting the engine from cold but with absolutely no throttle and leaving it to warm up and tick over for more than 12 minutes. This resolved the problem which never re-occurred.
Worth a try?
Logged
Yamaha RD200, Sachs 125, Ossa 350, Bonneville 650, Honda CB750, BMW R100RS, Honda Fireblade, Harley Hardtail, Kawa Ninja900, Tiger 800xc (won't mention the scooter)
Stevie.P
Tiger Jedi
'Arte et Marte'
Re: XRt cuts out
Reply #28 on:
January 09, 2019, 05:18:21 PM »
roy.c
... this involved simply starting the engine from cold but with absolutely no throttle and leaving it to warm up and tick over for more than 12 minutes. This resolved the problem which never re-occurred. Worth a try?
Known as the '12 minute reset' . it resets any 'adaptive' parameters back to base factory setting. Did it on my Street Triple after fitting a SC Projects Conic exhaust. Takes longer than 12 minutes to do though (as I was instructed) as the 12 minutes is taken from when engine fully hot and the radiator fan first cuts in and important not to touch the throttle, even when starting it up. Not sure how it would help with cutting out issue but can't harm anything trying it, the relevant 'adaptive' systems will adapt again with riding.
Logged
roy.c
Tiger Member
Bike: tiger 800XC
Re: XRt cuts out
Reply #29 on:
January 09, 2019, 05:24:28 PM »
Yes, I should have clarified that the engine needs to be fully hot before timing the tickover period. I was advised to cover the rad with foil to help it warm up faster (it was rather cold weather at the time)
Logged
Print
Pages:
1
2
3
4
5
11
Go Up
XRt cuts out
Led headlight/tft
Steve razor
Today
at 08:58:28 AM
TC disabled and Engine warning light
Brakes and ABS
chuckxc
Today
at 07:07:19 AM
Valve Clearances, values and interval to check
AvgBear
Today
at 02:04:23 AM
XCa Rear Sag - Confused!
AvgBear
Today
at 01:53:53 AM
tiger 850 sport - is a remap to 900 spec possible ?
Djairouks
Yesterday
at 08:52:48 PM
Swingarm play
AvgBear
Yesterday
at 05:06:26 PM
Centre Stand
Items "Wanted"
Adey Bee
Yesterday
at 04:52:58 PM
Subframe bolts
Big stu
Yesterday
at 04:41:05 PM
Hi from Gods country
New Members
kbar800
Yesterday
at 04:06:19 PM
Megameet 2021 postponed
2021 Tiger Mega Meet - Germany
Derchef1962
Yesterday
at 03:52:22 PM
