Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Probable rear wheel bearing failure  (Read 1279 times)
  • Bike: XC,XCX, CB1300,
Re: Probable rear wheel bearing failure
« Reply #10 on: December 30, 2018, 09:07:33 PM »
I have used a pressure washer on it, but kept clear of wheel bearings and chain. I don't know what happened to it in the 9000 miles before I got it though. Just hoping for decent weather at the weekend as the bearings and seals should be here by then.
That mysterious 9000 miles before you got the bike holds the answer I'd say. Someone did a s#t job on your wheels in a previous life. Suppose you will be replacing bearings in both wheels and the sprocket to be safe.
