Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Re: 2015 XCx Cold Start/No Start Issue  (Read 1991 times)
Offline tony-the-tiger
  • What we do on Sundays - Mt Lemon Riders Group, AZ
  • Bike: 2015 800 XCX
« Reply #10 on: January 07, 2019, 05:55:47 PM »
Thanks, Chuckxc;  I've gathered up a little pity from the selling dealer who says he will at least discount parts...new battery, plugs and oil go in tomorrow and it will start and run ... my prediction.  There is a root cause of these problems.  Blown ecu parameters are the possibility that's causing the fuel system and foul-up would account for oil in the crankcase. We also think all these things have contributed to a chain of events leading us to where we are.
tony-the-tiger
Online chuckxc
  • Bike: XC,XCX, CB1300,
« Reply #11 on: January 07, 2019, 07:03:59 PM »
I saw this same probem on a friends Triumph Sceambler ECU. He bought it second-hand and the owner had  let it sit for a year with a discgarged battery. ECU defaulted to base parameters so fueling was all wrong-ran way too rich.
« Reply #12 on: January 09, 2019, 08:33:26 PM »
Talked to Steve, the friendly Triumph dealer service writer about the issues last reported.  There was lost communication on the vent cannister...was not replaced but disconnected, hence two plugged vent lines.   I read somewhere one was to be plugged, the other left open...which one?  They are plenty pissed off with my revelations as to their incompetence...looks like that bridge has been burned.  New oil change, plugs and battery tomorrow...then road test ...stay tuned.
tony-the-tiger
Online chuckxc
« Reply #13 on: January 10, 2019, 05:25:21 AM »
And have the dealer re-load the ecu tune and run the adaption process too. They should know
to do that.
« Reply #14 on: January 10, 2019, 12:08:30 PM »
My name is mud there now...they should do this gratis,  but I'll have to go to the dealer in Phoenix, 120 miles...fight their backlog, it will probably be several day before I can get in.
He argued with me about the re-tune...says drive it...the ecu resets itself....  He's throwing the attitude...I won't give this dealer one more thin damn dime of my money.  OK to ride it to Phx?  I can trailer it and I need a trip there for my son anyway.
tony-the-tiger
Online chuckxc
« Reply #15 on: January 10, 2019, 09:43:22 PM »
Ride to phx up  to you, but if it was my bike it would get the tune re-loaded. You need to get back to a known base.
« Reply #16 on: January 11, 2019, 01:08:53 AM »
Thanks once again, chuckxc.  As I said in the beginning:  what I know about ecu's you can put on the head of a pin.  I will follow your advice....trailer the bike to Phoenix.
tony-the-tiger
« Reply #17 on: January 28, 2019, 04:29:16 PM »
After all this time, guys finally got it back together....starts and runs, but still has cold start issue.  To the dealer this week...stay tuned.
tony-the-tiger
« Reply #18 on: January 30, 2019, 07:00:50 PM »
Today, once started ran like it never had a problem.  Tomorrow morning:  Cold Start/No Start rares its ugly head again.  I put a hair dryer under it and a blanket atop for 1/2 hour.  It started, though with difficulty.  Took her up the mountain and the straightaways and ran it hard -  performed like a miracle.  Starts and runs with ease with a warm motor.  Tomorrow my appointment in Phoenix for the ecu tune and \ adaptive process.  Wish us luck.
tony-the-tiger
« Reply #19 on: February 02, 2019, 01:23:39 PM »
Back from the dealer today.  Many error codes found  -  battery and abs.  All systems checked out OK.  Starts and runs fine with warm engine.  Tech suspects  (if valves have not been adjusted) that low compression/valve adjustment will cause hard/cold starting issues in combination with a carbon buildup from maladjusted fuel mixture.  Suggests run SeaFoam through a couple of tanks of gas.
Following day:  this did not solve the cold start issue. But it can be started with careful throttle manipulation.
Following day:  warm blanket and hair dryer for 15 mins.  Starts right up.  Runs like there was never anything wrong.
3 things need to happen:  Valve adjust, an early summer...a large heating pad.  At least I'm riding again.
tony-the-tiger
