Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tight chain,  (Read 2787 times)
Offline walt
Re: Tight chain,
« Reply #20 on: January 23, 2019, 01:09:47 PM »
Ok, never considered not touching the adjusters, good practice is to remove, clean & re-grease them at every opportunity. I can see now how so many people have had them seize in the swing-arm, at great expense.  :005:  :087:
Think I'll continue doing like Frank says.  :152:
its a weak spot on a few bikes, mine get unscrewed and greased every time wheel is off
Re: Tight chain,
« Reply #21 on: January 23, 2019, 02:07:09 PM »
...  mine get unscrewed and greased every time wheel is off
 :0461: .... healthy coating of Copaslip .... as 'every time' isn't even once a year (more like 18 months), usually only tyre change time.  :028:
Re: Tight chain,
« Reply #22 on: January 23, 2019, 06:24:44 PM »
Bit confused here, not difficult :087: How come you only noticed when putting the wheel back? You would have had to back the adjusters right off to get chain off to get the wheel out.
You don't take the spindle out and then roll the wheel forward to release the chain? It's the way I've always done it, no need to readjust the chain afterwards then.
Re: Tight chain,
« Reply #23 on: January 23, 2019, 06:30:46 PM »
So you don't remove, clean & re-grease the adjuster either. Like said previously, no wonder so many are seized in swingarms. It's been posted up on here so many times yet people still persist in not maintaining that adjuster. Have you not read the last few posts.
Re: Tight chain,
« Reply #24 on: January 23, 2019, 06:34:41 PM »
Stainless adjuster bolts, copper greased when fitted. Haven't had any problems with them seizing.
Re: Tight chain,
« Reply #25 on: January 23, 2019, 06:50:10 PM »
Probably be ok, they aren't tightened as such. You may have noticed Triumph do not fit St/St screws into alloy, there is good reason.
https://www.essentracomponents.com/en-gb/news/product-resources/how-to-prevent-galling-on-stainless-steel-bolts
Re: Tight chain,
« Reply #26 on: January 24, 2019, 11:26:54 AM »
Luckily then that the adjuster screws aren't directly into alloy .. but steel (boss type) thread inserts.  :028:
Re: Tight chain,
« Reply #27 on: January 24, 2019, 12:18:00 PM »
Ok, I should go specsavers. The issue of corrosion is only marginally increased in that case then. See link below. I would still remove, clean & re-grease the adjustment screw at every wheel out though. Why wouldn't you.
http://www.preservationscience.com/materials/metals/PGC.html
« Last Edit: January 24, 2019, 12:27:14 PM by Paulhere »
Re: Tight chain,
« Reply #28 on: January 24, 2019, 12:40:53 PM »
Have S/S screws fitted and as said previous post personally I agree and do.  :028:
Offline Dick
  • Bike: tiger 800xR
Re: Tight chain,
« Reply #29 on: January 24, 2019, 05:56:22 PM »
Sorry did not mean to open a bag of worms ,But very interesting site on corrosion.
