Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tight chain,  (Read 3840 times)
Re: Tight chain,
« Reply #30 on: January 24, 2019, 10:07:37 PM »
*Originally Posted by Dick [+]
Sorry did not mean to open a bag of worms
Prolly OK? -- folks got an education on metals/corrosion.
But...
The markings on the swinging arm can be inaccurate
Are they or aren't they?
Can the Triumph factory mark the swingarm correctly?  :187:
"Working on a motorcycle, working well, caring, is to become part of a process, to achieve an inner peace of mind.
The motorcycle is primarily a mental phenomenon."
Robert M. Pirsig
Re: Tight chain,
« Reply #31 on: January 25, 2019, 10:03:41 AM »
It'll be done & checked in a fixture, Triumph adhere to their 1 in 10 check on all operations, any fail & the previous 10 are pulled for thorough inspection. Their q/c is excellent, standard automotive procedure.
Dicks issue would more likely be caused by a PO or dealer oik.
Offline skinneroo
  • Bike: tiger road
Re: Tight chain,
« Reply #32 on: January 26, 2019, 06:02:27 AM »
Swing arm marks are within 0.5mm. It's what I expected as the arms will be cnc machined.
My measuring equipment was rudimentary, but i'm happy to trust the marks when adjusting the chain. :002:
Re: Tight chain,
« Reply #33 on: January 26, 2019, 11:02:10 AM »
*Originally Posted by skinneroo [+]
 :0461: With the way todays bikes are machined and assembled (including the frame) I would expect the swingarm adjuster indicator marks to be accurate enough for the bikes design use. On the other hand I freely joke that my, manufactured lots by hand on knackered old machinary, Meriden Bonneville was made to +/- 1/4".  :008:
Offline Sandal farm
Re: Tight chain,
« Reply #34 on: January 30, 2019, 11:03:43 PM »
A good idea to keep the adjuster  free as it's just cost me 60 to have the broken bolt spark eroded out of the swing in arm,  on the upside after rerouting the brake line wrongly I can now do the job really quickly
Re: Tight chain,
« Reply #35 on: February 06, 2019, 01:05:02 PM »
Probably be ok, they aren't tightened as such. You may have noticed Triumph do not fit St/St screws into alloy, there is good reason.
https://www.essentracomponents.com/en-gb/news/product-resources/how-to-prevent-galling-on-stainless-steel-bolts
Triumph are using whirry tool things to screw in their fasteners at high speed, I'm not. And I use copper grease too. This might explain why, in 40 years of screwing stainless fasteners into aluminium, I've never had a problem.
Gone but not forgotten: Tiger 1050, Bonneville SE, Sprint ST 955i, Trophy 4, Sprint 900, Daytona 900, Tiger 900, Trident 900
Re: Tight chain,
« Reply #36 on: February 06, 2019, 03:45:51 PM »
 :0461:  My 40yr old Meriden Bonnie has S/S screws fitting direct into alloy threads cut in the covers/casings (they didn't fit steel thread inserts back then, just used course pitch thread) and Copaslip and correct application of torque/tightness means I've never had to repair one yet.  :002:
Re: Tight chain,
« Reply #37 on: February 06, 2019, 05:28:33 PM »
Interesting discussion.
A story: I was in the nut & bolt section of a local hardware store and met a m/c buddy who's a machinist/founder (he makes re-pop items for collector bikes) and I said, "Hey Mike, look - they've got stainless steel fasteners." He said: "Why would you want those? (his reply was actually more colorful...) They'll just cause galling of the threads."
It caused me to re-think things -- as all may not be as simple as perceived at first blush...
Another story -- an automotive machinist once gave me these words of wisdom: "Never let metal know you're in a hurry."
Robert M. Pirsig
Re: Tight chain,
« Reply #38 on: February 06, 2019, 06:38:06 PM »
I don't recall Meriden Triumph using St/St fasteners into alloy, can't imagine where. It's against all engineering principals. And far too costly to ever get past the accountants.
Boys in the club who've done a proper restoration job, had all the undamaged original fasteners re-plated.
Re: Tight chain,
« Reply #39 on: February 08, 2019, 03:03:45 PM »
They didn't. I, and many others, did. I've never had, or heard of, any problems. Not just with Meriden Triumphs, with any bikes. I've had to use extreme violence on many a non-stainless fastener, though.
