Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: kriega Fork Seal covers fitted today question  (Read 471 times)
Offline steveg
  • Bike: 2012 T800 roadie
« on: January 03, 2019, 01:52:12 PM »
Finally got round to buying some Kriega Fork Seal Protectors today , to hopefully stop the winter crap getting into fork seals
Fitted nice and easy and looks good
My question is are they are a fit and forget or do you need to clean them underneath from time to time ?
Do they need some WD40 or something on the covers to lubricate them or do you keep them dry so not to attract dirt
Cheers Steve
Tiger 800 roadie 2012
Re: kriega Fork Seal covers fitted today question
« Reply #1 on: January 03, 2019, 04:30:28 PM »
Nothing is fit and forget.  That's just lazy.  Best to remove and check every few months and some lubrication also.  WD40 is not lubrication.
Stupid is as stupid does.
IRL via GB & CL
Offline steveg
« Reply #2 on: January 03, 2019, 04:33:05 PM »
Thanks for the reply , what do you use to lube the fork protectors  ?
Cheers Steve
« Reply #3 on: January 03, 2019, 07:35:55 PM »
*Originally Posted by steveg [+]
Cheers Steve
Wash the protectors with warm water and mild detergent.  Then sparingly apply some red rubber grease or something designed for rubber/foam.
WD40 is no good as at best can only be described as a very weak lubricant.
IRL via GB & CL
Offline steveg
« Reply #4 on: January 03, 2019, 08:03:14 PM »
 :460:
Many thanks
Cheers Steve
Offline Nick_2112
« Reply #5 on: January 04, 2019, 10:51:36 PM »
