Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Shim set adjusting valves  (Read 1527 times)
Online Rorut
  • Bike: Tiger 800 XC
« on: January 05, 2019, 11:22:47 AM »
Any recommended shim set that I can buy just to be prepared when doing the job
Thanks!
Offline tewe
Re: Shim set adjusting valves
« Reply #1 on: January 07, 2019, 07:54:27 AM »
Check this one, it has just been discussed recently:
https://www.tiger800.co.uk/index.php/topic,23666.0.html
tewe
Offline t_revs
« Reply #2 on: January 14, 2019, 03:01:20 PM »
I have just done the shims on my 800R are after - wait for it - 26,000 miles. Yeeha. It was running fine so I just left it until I started getting paranoid.
By the way the airfilter was what you might call black. 14 off ebay.
So Exhaust gaps - .30  .31    .30  .31    .37  .37
     Inlet               .16  .17    .16  .18    .17  .16
Weird that the cam sprocket side should open up and not close up like the rest.
I think its no point in buying a kit for 50 as I actually only had to buy 4 shims ( I mixed and matched 5 existing shims) from Bikeaholics on ebay at 4.99 each.
Buy from Bikeaholics as they seem to be the only seller with shim increments of .025, most are .05 which did not work on some gaps. In fact 3 shims were a Triumph size of 2.48, a strange size. Also checked the gaps 3 times to make sure of the right sizes. Yeah a bit anal but was worth it.
I bought a 32 blade MM feeler gauge off ebay, you'll need to curl the end to fit in the gap.
I also made a crib sheet to make sure I didn't make a mistake. Gap size goes in circles, old shim to new shim sizes underneath.
Hope this helps.
T_revs
Online Rorut
« Reply #3 on: January 19, 2019, 11:12:00 PM »
Thanks a lot! Very helpful.
Online Rorut
« Reply #4 on: January 20, 2019, 08:02:11 AM »
Last time previous owner had the valves checked was at 18K.
No changes needed to be made
Bike has now 24K. What is the interval between the controls?
Offline grizzlybear
  • Bike: tiger 800 ABS
« Reply #5 on: January 20, 2019, 08:06:48 AM »
12000 miles  :028:
Safe Riding
Online Rorut
« Reply #6 on: January 20, 2019, 08:57:23 AM »
Hope Im good for the 6K that is left and can do it after this year season.
« Reply #7 on: January 20, 2019, 10:11:45 AM »
. though if serviced as per the official Triumph schedule this would be done at 12k, 24k, 36k, etc. So 18k was 6k early or more likely 6k late?
(Engine block - top right)
Online Rorut
« Reply #8 on: January 20, 2019, 10:52:08 AM »
Checked 6K late
« Reply #9 on: January 20, 2019, 11:15:05 AM »
As you are happily doing your own maintenance and know they were done at 18k it clearly doesn't matter about the schedule mileage, just do at your judgement.  :028:
