Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Shim set adjusting valves  (Read 1523 times)
Offline street tango
Re: Shim set adjusting valves
« Reply #10 on: January 30, 2019, 12:30:03 PM »
. though if serviced as per the official Triumph schedule this would be done at 12k, 24k, 36k, etc. So 18k was 6k early or more likely 6k late?
(Engine block - top right)
How come they failed to lube suspension linkages that should have been done????
No wonder so many fail!!!!
« Last Edit: January 30, 2019, 12:51:02 PM by street tango »
« Reply #11 on: January 30, 2019, 10:40:27 PM »
*Originally Posted by street tango [+]
It didn't slip past me, or the fact that again (as on 6k service) they didn't renew the chain rubbing strip. It went back in a few days later to have both items rectified. As the bike was on a service plan, the cost including parts, I insisted the chain rubbing strip be renewed as per Triumph schedule, worn or not. :232:
While the service schedule calls for the suspension linkages to be lubed there appears to be no mention of ever checking/lubing the swing arm bearings. I think as servicing will now be down to me, at the next (24k) service this summer I will grease them. :028:
« Reply #12 on: January 31, 2019, 06:51:35 AM »
To be fair I wouldn't bother. They are sealed bearings, with only a small amount of movement. I have never heard of any failing, unlike the linkages that fail on a regular occurrence and seems any triumph.
btw this is not the 1st time I have seen this on a tick sheet.
Offline Rorut
  • Bike: Tiger 800 XC
« Reply #13 on: February 05, 2019, 04:07:04 PM »
Anyone using Molybdenum disulfide grease on the parts that cover the shims? Read something about it in the manual
« Reply #14 on: February 05, 2019, 07:11:38 PM »
Mr. Haynes say: "Lubricate the new shim with molybdenum disulphide oil (a 50/50 mixture of molybdenum disulphide grease and engine oil) ... then lubricate the follower with molybdenum disulphide oil"
Whilst moly is certainly a good anti-wear additive - modern engine oils, themselves, are formulated with all the additives normally needed.
I tend to shy away from additional additives in engine oil -- but, will liberally oil these parts when re-fitting.
Offline Rorut
« Reply #15 on: February 06, 2019, 08:45:55 PM »
Almost everyone out of spec:
I had some problems measuring. It felt different depending from which way I measured. Some of them could only be measured from one direction but a few from both and it did not felt the same.
https://i.postimg.cc/pVJ7Q1YZ/327463-A1-8-BE5-4808-86-EB-098-B0302-C051.jpg
« Reply #16 on: February 06, 2019, 09:10:54 PM »
The way I read it - all the inlet valve clearances are in-spec.
But only one exh. valve clearance is in-spec -- the other 5 have less than recco'd clearance.
Offline Rorut
« Reply #17 on: February 06, 2019, 09:32:15 PM »
Thanks Avbear!
Does this look ok?
« Reply #18 on: February 06, 2019, 09:53:48 PM »
Thanks Avbear!
You're welcome.
Does this look ok?
Yes -- all clearances nicely in-spec.
Offline Rorut
« Reply #19 on: February 06, 2019, 10:08:18 PM »
Is 0.260 considered harmly out of spec? And can 6000miles really make a difference related to my measurements?
