Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2018 Tiger Indicators  (Read 1394 times)
Offline Cooperbiker
Re: 2018 Tiger Indicators
« Reply #10 on: May 22, 2019, 11:03:00 PM »
Try  A9830046.  Same for front and rear so you need to order x2 at 102 per pair (204 total)
Many thanks for this. I've subsequently discovered from https://www.triumphworld.de/product_info.php?products_id=211242 that the 2018 plastic XRT LED indicator (and presumably the XRX is the same) is part number T2701144. This costs 36.00 / 38.88 / $46.08 at worldoftriumph.com for a single one, so it is a bit cheaper than the accessory indicator. (I only need one to replace a broken one after a drop).
« Last Edit: May 22, 2019, 11:04:56 PM by Cooperbiker »
Offline Cooperbiker
« Reply #11 on: May 27, 2019, 05:19:51 PM »
*Originally Posted by Cooperbiker [+]
Received replacement indicator T2701144 from World of Triumph and can confirm this is the correct original part.
