Do any one knows how to romove The vibrations in my 800 xrt 2018
Its starts in 6000 rpm. Abaut 120 km/h. Then i cant see in The morrows and there is
annoying vibrations In the sterings ends.
have some experience with how to remove the vibrations.
Regards cla
I have that problem.
I had the dealer change the off side mirror (which was blurry) which has helped with the rear view vision but compared to my previous Tiger XRX (which had NO perceived vibration) my current XRT definitely is vibey above about 5500 rpm.
The dealer checked the engine mounting bolts and said that one bolt was slightly loose. The throttle bodies balance was fine, they said.
So at the moment I am living with this problem. When the road salt has gone I will try softening the front suspension and maybe change the Tourance tyres seeing as the vibration is felt through the bars.
The sterling head was over tight (so much for Triumph build quality) but seems ok since the dealer slackened off the head.
I need some other XR rider to try out my machine and report back. My short legs prevents me from taking out a demo machine. :110
So, we persevere!!
Regards.
