We are in the planning stages of a trip to Morocco in October and a friend was telling me the air filters are problematic on my new to me XCX and I should fit a uni filter. My question is would a k & n not just do the trick?
No.
The problem is not so much the filter material as the access. With practice it is a good 45 minutes - 1 hour to get to the air filter replace it and put everything back together. Try doing that every couple of days on a trip in dusty conditions and the novelty will wear off very quickly.
With the Unifilter it is take the seats off take the cover over the ABS pump off and take the left side panel off and you can remove the pre filter clean it and put it back together in 10-15 minutes. Better still if you are on tour take two Unifilters and swap them so you always have a clean one on hand. With the Unifilter you will never need to get to the main air filter and it will maintain it's superior (now secondary) filtration.
Some riders even put a section of nylon stocking over tehn pre filter that can simply be slid off and shaken out in extremely dusty conditions.
K&N filters are crap anyway they are the last thing you want to be using to protect your engine is dusty conditions.
