So I have had this metallic squeaking started from the front wheel I knew the front pads were getting low so I have replaced them only to find I still have the squeak which is loud, on closer inspection I have noticed the ABS sensor is rubbing on the serrated grooves on the disc should the sensor be touching the disc if no what could have happened I have checked the rear ABS sensor but cannot tell from that.
