Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Wiring aftermarket fog lights  (Read 1050 times)
Offline tony-the-tiger
  • What we do on Sundays - Mt Lemon Riders Group, AZ
  • Bike: 2015 800 XCX
« on: February 16, 2019, 01:04:24 PM »
I read several posts advising tie in the fog light wiring to the horn circuit  -  "blue and white wire".  This way power is energized through the ignition....power is off when the ignition is off....a good plan.   Where exactly is this "blue and white" wire located?
tony-the-tiger
Offline pme
  • Bike: xrx lrh 2018
Re: Wiring aftermarket fog lights
« Reply #1 on: February 16, 2019, 03:05:33 PM »
if its a pre 2018 model the wire is on the horn under the beak at the front, if its a later model then that does not work, search site for "white connector under seat"
Offline lanerider
  • Bike: tiger 800 xcx
« Reply #2 on: February 16, 2019, 03:21:35 PM »
i have my tyre pressure sensors wired to the horn could i also power my Garmin sat nav as well
Offline pme
« Reply #3 on: February 16, 2019, 03:55:18 PM »
IIRC its a 15amp fused cct so the tyre sensors use almost nothing, the horn connection is very popular for sat  nav, just might be an issue with a long horn blast combined with a charging sat nav might pop the fuse but i doubt it
Offline lanerider
« Reply #4 on: February 16, 2019, 03:57:02 PM »
Thank you for your help Ill give it a go
« Reply #5 on: February 16, 2019, 10:22:19 PM »
Thanks, all...good info.
tony-the-tiger
Offline troop
  • Bike: 2016 800 XCXR
« Reply #6 on: February 25, 2019, 01:58:09 PM »
On my 2016 XCx, I have my upper fog lights mounted to the horn circuit. Fast/easy job using the piggy back spade. I just wired a 2nd pair of fog lights on my lower fork tubes. I connected those to the high beam circuit of my headlights. They'll only be on when my high beam light is activated.
Offline gordybrock
  • Bike: Tiger 800XR 2012
« Reply #7 on: February 25, 2019, 02:55:51 PM »
*Originally Posted by lanerider [+]
I used the horn blue/white with a piggy-back spade connector, wired my Zumo, spotlights and GoPro camera to it... 4k miles later no probs.  :152:
I'm from Wigan Me
« Reply #8 on: February 25, 2019, 03:52:58 PM »
Thanks to the info I get from here and you gentlemen, have likewise wired mine to the horn circuit.  Aftermarket everything, including the Denali mounting bracket from Revzilla ($40) and the lights,  I'm in the game for less than $100 and a professional look to everything.  Pics to follow.  Beats the $500 plus for the factory OEM's.  I picked the halogen bullets...flood lights, to match the headlight color and quality.
tony-the-tiger
Offline gordybrock
« Reply #9 on: February 25, 2019, 07:14:01 PM »
*Originally Posted by tony-the-tiger [+]
...I'm in the game for less than $100 and a professional look to everything.  Pics to follow.  Beats the $500 plus for the factory OEM's.  I picked the halogen bullets...flood lights, to match the headlight color and quality.
 :493:  :0461:  Triumph spotlights 320 pair PLUS the wiring harness, simply outrageous money for what you get.
I'm from Wigan Me
