Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Wiring aftermarket fog lights  (Read 837 times)
Offline gordybrock
  • Bike: Tiger 800XR 2012
Re: Wiring aftermarket fog lights
« Reply #10 on: February 25, 2019, 07:15:13 PM »
:493:  :0461:  Triumph spotlights 320 pair PLUS the wiring harness cost, simply outrageous money for what you get.
I'm from Wigan Me
Offline troop
  • Bike: 2016 800 XCXR
« Last Edit: February 26, 2019, 07:06:12 PM by troop »
Offline mulanee
  • Bike: Tiger 800 2014
« Reply #12 on: February 27, 2019, 10:55:56 AM »
*Originally Posted by pme [+]
IIRC its a 15amp fused cct so the tyre sensors use almost nothing, the horn connection is very popular for sat  nav, just might be an issue with a long horn blast combined with a charging sat nav might pop the fuse but i doubt it
If you install a relay, there is no fuse issue because there is no power to spend.
I just inserted the wire inside the closest horn connector from the left side (blue/black wire), til now it works.
