Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Bark busters interfere with clutch cable  (Read 852 times)
Offline Rorut
  • Bike: Tiger 800 XC
« on: February 20, 2019, 07:32:10 PM »
Bought a set of used bark buster storms.
Only way I can install it is having the clutch cable above the clamp.
And it is very tight. Any advice on this is appreciated
Offline Bikerjimbob
  • Bike: Tiger 800xca
Re: Bark busters interfere with clutch cable
« Reply #1 on: February 20, 2019, 07:51:32 PM »
That's exactly the same problem I have, I have looked around for other options and come up with nothing yet other than i filed away a small amount of the handlebar clamp to allow the cable to have no strain on it where it enters the lever but still to close for my liking.
Cheers Jim
Offline Rorut
« Reply #2 on: February 20, 2019, 08:03:23 PM »
That is strange designed like that. Almost want to heat it red and bend it
« Last Edit: February 20, 2019, 08:10:21 PM by Rorut »
« Reply #3 on: February 20, 2019, 08:03:32 PM »
I have a good thumbs length from the cable adjuster to the barkbuster clamp and a fingers width (1cm) between cable and top of clamp.
Is your cable correctly routed?
or you might have the barkbuster rotated too far up, or you have the metal spines on upside down, ie Left on right and visa versa.
Stupid is as stupid does.
IRL via GB & CL
Offline Nick_2112
« Reply #4 on: February 20, 2019, 08:06:40 PM »
As KildareMan, Mines OK with BB.
Offline Rorut
« Reply #5 on: February 20, 2019, 08:21:26 PM »
I did not change any angle on anything else.
At the moment it look like this:
(In paralell with the lever)
https://postimg.cc/gallery/ketv8qzo/
« Last Edit: February 20, 2019, 08:23:13 PM by Rorut »
Offline UncleGary
« Reply #6 on: February 20, 2019, 09:04:16 PM »
I have the Barkbuster Storms on my 2012 Roadie. No problems. Looking at the picture, it seems that the height of the bars may have an influence? Just an idea.
Offline Bikerjimbob
« Reply #7 on: February 20, 2019, 09:07:52 PM »
My BB came off my BMW R100GS that was written off a couple of years ago so not made to fit my tiger but fit very well apart from the clutch cable issue, think I will take that one off this morning get it in the vice and see if I can put a little bit more bend in it so the clutch cable passes over properly.
Looking at the pictures I loosened my brake hose and moved it down to pass under the BB as I figured if the bike goes down any movement of the BB will be upwards not down (just my opinion)
Cheers Jim
Offline Rorut
« Reply #8 on: February 20, 2019, 09:37:58 PM »
Will not leave my rox risers :(
Anyone tested this item?
https://www.twistedthrottle.com/barkbusters-angled-swivel-clamp-to-replace-straight-swivel-clamp
https://goo.gl/images/gVW5ur
« Last Edit: February 20, 2019, 09:49:59 PM by Rorut »
Offline Blitzy
  • Bike: 18 Tiger 800 XCa
« Reply #9 on: February 20, 2019, 10:32:27 PM »
Barkbusters sell a separate part that has a u shaped step to allow the cable to pass. https://www.mxstore.com.au/p/Bike-Parts/Handlebar-End-Caps/Barkbusters-Offset-Swivel-Connector/BB-054
I had the same problem but fitted one and now its perfect.
