Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2018 Tiger GPS mount between screen  (Read 515 times)
Offline TDU
« on: February 24, 2019, 03:02:59 PM »
After purchasing and fitting my Bike-pen-R GPS mount on the handle bar clamps, I decided to move the GPS as I found that it was not ideal looking down at it.
So I fabricated this setup which mounts between the screen and doesn't require any drilling.
Basically I bought two 8mm battery lugs and a $1 piece of 8mm steel round bar.
I bent the bar in a vice, rounded off the ends and attached the lugs which screw onto the screen.
The cable runs down the side of the bike just behind the side panels and attaches neatly to the battery.
See attached pics... 😀
When i can upload them 😀
Suzuki GSX1400
Yamaha XT250 (Missed)
Yamaha XT660
Triumph Tiger 800 XRx
Offline TDU
Re: 2018 Tiger GPS mount between screen - Pics Attached
« Reply #1 on: February 24, 2019, 10:57:03 PM »
Pics Attached
Rode with it this morning and much neater ..  :047:
I also attached a picture of how I had it before. Was still very neat but I found looking down a bit distracting... :038:
Happy to pass on details of the design.
« Last Edit: February 24, 2019, 11:10:03 PM by TDU »
Suzuki GSX1400
Yamaha XT660
Offline Lazzy71
« Reply #2 on: February 25, 2019, 10:07:54 AM »
Hi TDU, Neat idea but how does the battery lugs connect to the bar bolted or soldered? I have a Touratech mount for my TomTom and this would be perfect.
Offline TDU
« Reply #3 on: February 25, 2019, 10:35:04 AM »
Hi Lazzy
The lugs are copper so i decided to epoxy glue the 8mm bar into the lug. I did grind a few cuts into the end to give it something to hold on to.
The epoxy is quick drying and it wont come out.
Happy to help if you need more info.
PS. Im very happy with the result.
Marc
Suzuki GSX1400
Yamaha XT660
Offline SteveB610
  • Why do I ride, because I can 👍🏍
« Reply #4 on: February 26, 2019, 12:50:38 PM »
Hi TDU
This looks substantial. I have a 2018 Tiger XRX
could you post a picture from the front , with the GPS attached.
Did you use the GPS mount for a 2017 Bike ?
Also can the screen still be moved into most positions?
Could you post the design details please
Cheers Steve
Offline TDU
« Reply #5 on: February 26, 2019, 11:19:55 PM »
Hello Steve
Nice to meet
I also have a 2018 XRx .. In the best colour BLUE  :001:
I experimented a bit with angles - the first one I made I bent the bar a bit less and the GPS sat just above (about .5cm) the TFT display
The second one I made - I bent a bit more and it sits about 1.5cm above the display
The two bolts don't affect the screens movement - but you obviously cant use the screen on the lowest setting
The design looks something like this :
                             ________
the lugs are attached to the ends of the 8mm bar and just epoxy glued in
I ran the wire down the side and behind the TFT bracket, along the tank and into the battery
Here is a pic from the front
The GPS mount is a Bike-Pen-R mount   https://www.motogps.com.au/bikepenr/
Marc
« Last Edit: February 26, 2019, 11:21:30 PM by TDU »
Suzuki GSX1400
Yamaha XT660
Offline Ash
« Reply #6 on: March 14, 2019, 07:16:13 PM »
Mounted sat nav bracket above TFT screen, video on my Facebook page
Excuse heavy breathing 😝👍
https://www.facebook.com/groups/200056950341426/permalink/827669094246872/
