Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: General Maintenance  (Read 669 times)
Online Joe_Dee
  • Bike: 2017 XCx
General Maintenance
« on: March 20, 2019, 07:04:55 AM »
Hi all
I'm picking up my first Tiger on Saturday, a 2017 XCx, and was wondering if there was anything (maintenance wise) specific to the Tiger that I need to keep an eye on. I haven't had too much time yet to browse the forums but one thing I noticed was that some seem to use quite a lot of oil, something I am definitely not used too with my current Speedmaster.
Anything else I need to watch for ?
Joe
Re: General Maintenance
« Reply #1 on: March 20, 2019, 08:57:32 AM »
Take the chain adjusters out and give them a good coating of anti-seize paste
You could also swap for stainless steel ones (of the top of my head ) M8 70
I also covered up the big holes on the inside of the swinging arm
« Reply #2 on: March 20, 2019, 09:23:40 AM »
So many variables.  Oil.  Never used any between changes in 8 years.
What RTwo says.  I would add
1.  EBC HH pads
2.  keeping calipers clean
Offline Silverstripes
  • Avatar my 955i Tiger 2003/4
« Reply #3 on: March 20, 2019, 10:43:37 AM »
My 4d worth, rear suspension linkages. Very little grease from factory  :009: and worth a little time to avoid spending when the bearings wear out. Had the same with my Trophy  :169:
It wasn't me !!
Offline street tango
« Reply #4 on: March 20, 2019, 01:54:56 PM »
Totally agree.
  • Bike: XC,XCX, CB1300,
« Reply #5 on: March 20, 2019, 08:33:35 PM »
Adding to these posts, some basics...
Around 100k km on the 2012 XC, I never added oil between changes.
But... usually changed oil&filter earlier than 10k km interval based on how hard the engine worked between changes.
Suggest you keep clutch cable lubed, mine broke at the lever after 80k km.
Keep a check on wheel&sprocket bearings. Easy to replace if necessary.
Front & maybe rear sprockets will wear, replace if worn. Good chain maintenance helps.
Keep area below battery clean, corrosion of main fuse otherwise.
« Reply #6 on: March 20, 2019, 08:40:39 PM »
My 2014 Roadie (semi synthetic oil) never used any between services.
My 2016 XRX (full synthetic oil) used a small amount between the first two services but has now settled down and does not use any.
Online Joe_Dee
  • Bike: 2017 XCx
« Reply #7 on: March 20, 2019, 11:17:28 PM »
Thanks for the advice, plenty to keep me busy
Offline herdygerdy
  • Bike: 17 White XRT
« Reply #8 on: March 21, 2019, 08:15:58 PM »
On front and rear calipers, remove the brake pad pins, that sit behind the little slot head grub screw (1 per caliper) and give them, and the grub screw a bit of "slippery love" with Copper Kote or similar.  IIRC the brake pin has a hex head (or allen head if you prefer).
I've heard some on here have had them seize and be a bear to remove, making a 20 min pad change a hair tearing experience.
And black duck tape to cover the swinging arm holes to prevent ingress of mud and gloop.
