Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Chain and Sprockets?  (Read 610 times)
Online kamperman69
« on: March 20, 2019, 01:17:02 PM »
I'm A bit confused what size is the Chain & Sprockets on a 2018 XRT.
 Are they the same as a 2017 :006:
Re: Chain and Sprockets?
« Reply #1 on: March 20, 2019, 02:15:31 PM »
Tiger 800 XR - All Models
Final Drive Chain DID O-ring, 124 link
Online kamperman69
« Reply #2 on: March 20, 2019, 07:16:21 PM »
Cheers Kildare Man  :028:
Has anyone any suggestions of a good rear sprocket.
« Reply #3 on: March 20, 2019, 08:38:00 PM »
Got mine as a kit from
https://www.squaredeals-ltd.co.uk/chains--sprockets-tiger-800--800xc-786-c.asp
Go for X ring.  Better than O ring.
« Reply #4 on: March 20, 2019, 08:46:42 PM »
I had already decided I would replace the standard factory O ring chain with a better quality X ring chain and then went about doing a bit of sprocket research. The final conclusion I made from various sources was that JT sprockets are pretty much the best (standard type) sprockets available, so that is what I went with, I wasn't going to pay for good chain and then fit poor quality sprockets.  :028:
https://www.tiger800.co.uk/index.php/topic,24021.0.html
Online kamperman69
« Reply #5 on: March 21, 2019, 06:56:02 PM »
 Yep Stevie.P that's what I've done :169:
 Thanks for the advice.
Offline grizzlybear
  • Bike: tiger 800 ABS
« Reply #6 on: March 22, 2019, 06:32:44 AM »
I replaced mine with a X ring chain after 32000 miles,  seems the latest chain technology uses a Z ring 🤔
Safe Riding
Dave( Grizzlybear) honda 125T,  Z650C2, GPZ750, GTR1000, VX800, VN1500 ,tiger800 and loads of C90`s  :)
Offline herdygerdy
  • Bike: 17 White XRT
« Reply #7 on: March 22, 2019, 08:21:57 AM »
StevieP, thanks for the great info' on your older chain 'n sprockets replacement thread, nice job.
Did you ever drop some extra links off the 124 link OEM length so as to move the wheel further forward on the adjustment slots in the swinging arm?  But understand doing that would prevent the installation of larger diameter sprockets though, if that was your persuasion...
Tks...Tony
« Reply #8 on: March 22, 2019, 08:47:54 AM »
*Originally Posted by herdygerdy [+]
Did you ever drop some extra links off the 124 link OEM length ...
No, because as yet the wheel hasn't barely been adjusted rearward. Since that reported initial adjustment after the Megameet mileage last May I have only needed to adjust once more, another 1 full turn on each adjuster screw. I still want to try dropping the links eventually, for interest mainly to see how much difference it creates. The critical part will be the actual chain condition at the point this is possible. If the chain was well within wear specs I would be tempted to drop the links and renew the front sprocket and see how it runs?
