Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Very Flexable Turn Signals  (Read 563 times)
Offline Tigercoyote
  • Preferred Definition Coyote=Roaming North America
  • Bike: 2018 Tiger 800XR
« on: March 21, 2019, 12:34:27 AM »
Greetings All,  :490:
Although I haven't had the opportunity to knock off my turn signals on past 800XC or my present 800XR, I wanted to put these flexible LED turn signals on before I experience the classic broken dangling Tiger 800 turn signal out on the trail. I'm sort of a newbie with forms so I put all the info available into my photo album titled "My Tuff light installation". Follow starting with picture 1. They are plenty bright as well. Comments & ?s welcome.
Cheers-N-Beers!
« Last Edit: March 21, 2019, 12:41:14 AM by Tigercoyote »
Result of WWII, 1/2 Cajun 1/2 Aussie
Re: Very Flexable Turn Signals
« Reply #1 on: March 21, 2019, 09:11:51 AM »
Looks good.  Personally I would have moved them higher, but otherwise  :028:
Offline JMc
  • Bike: tiger800
« Reply #2 on: March 21, 2019, 01:19:09 PM »
As Kilderman, relocate up to the headlight, cable's are long enough  :152:
Offline Tigercoyote
« Reply #3 on: March 21, 2019, 02:32:03 PM »
Mounting up near headlight is brilliant..great idea!! I may still do that and use a blank tab over stock signal position. Thanks for feedback!!
« Reply #4 on: March 21, 2019, 02:36:02 PM »
*Originally Posted by Tigercoyote [+]
Scrap of black plastic silconed Black) on from the inside.
Offline SteveTT800XRT
  • Bike: TT 800XRT
« Reply #5 on: June 05, 2019, 01:22:50 PM »
Looks good Kildareman, I have just bought the same indicators.
Removal of existing indicators, loosen allen nut and pull through, cables as well?
Or is it a removal of panels and loosen from behind? :465:
  • Bike: TT 800XRT
« Reply #6 on: June 05, 2019, 01:36:32 PM »
*Originally Posted by SteveTT800XRT [+]
Looks and feels like removal of panel next to radiator and loosen from behind, feels like a nut & bolt connection to the fairing. Then fabricate a piece of steel of aluminium from plus/minus 4 cm drill two holes and fix onto nut holding fog lamps :087: :087:
« Reply #7 on: June 05, 2019, 08:07:36 PM »
Not a difficult job.  A little fabrication - new attachment.  Remove the panels with the indicators attached.  Remove indicators.  I cut the Triumph connectors off the Triumph indicators and attached to new indicators rather than remove Triumph connectors from the bike loom.  Soldered and heat shrink applied.
