Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Shoei Neotec II, Black, Medium - worn for 2 hrs. SOLD  (Read 480 times)
Offline Fuge
  • Bike: 17 Tiger 800 XCx
« on: April 05, 2019, 05:28:11 PM »
So it felt fine and snug in the shop but after the 2 hour ride home from Chester it felt like my poor noggin was about to implode.  :005:
Cost me around 520 but will let it go for half that.
It's black and the medium size, boxed with all the trimmings.
Any one interested?
« Last Edit: April 07, 2019, 12:05:38 PM by Fuge »
Offline Flyfifer
  • Bike: Tiger 800 XR
Re: Shoei Neotec II, Black, Medium - worn for 2 hrs.
« Reply #1 on: April 05, 2019, 06:42:06 PM »
 :084: I bought a large and had exactly the same experience on a long run.
I took out the cheek pads and that made it OK. A few thousand miles later it fits perfectly.
You might want to try that before selling.
Offline lanerider
  • Bike: tiger 800 xcx
« Reply #2 on: April 05, 2019, 08:04:29 PM »
i have one with the built in intercom after 100 mile it fits like a glove and the best helmet i have ever had .. try a few more miles till it beds in
« Reply #3 on: April 05, 2019, 08:32:17 PM »
Couldn't you get replacement cheek and centre pads for the next size up?
Offline T120R
  • Bike: Tiger 800 T120R
« Reply #4 on: April 06, 2019, 09:11:24 AM »
I have version one which I have used for years and loved but when I tried version 2 in the shop it was really uncomfortable crushing my cheeks even in a larger size.
Offline Fuge
« Reply #5 on: April 06, 2019, 11:27:05 AM »
Thanks for the comments and suggestions chaps, but it was pressure from the top rather than the sides that was the issue. Thus, I don't think any modulation of the cheek-pad configuration is going to help.
Happily, a fellow forum member is up for it - provided I cough for the postage.  :015:
Offline steveg
  • Bike: 2012 T800 roadie
« Reply #6 on: April 06, 2019, 12:38:22 PM »
Howdy
Not a Shoei , but I bought a Caberg helmet in size M ( I.m between a M and L helmet size)
Large was comfy to fit from shop
Medium was a bit tight fit from shop
Turned out the medium was really painfull after about an hour riding , even living a mark on the skin
After 2 weeks daily riding fitted like a glove
2 years later the medium is slightly loose fitting ...
Might be worth giving it some more time if u can
cheers Steve
Tiger 800 roadie 2012
« Reply #7 on: April 06, 2019, 01:34:32 PM »
*Originally Posted by Fuge [+]
... but it was pressure from the top rather than the sides that was the issue.
Besides a range of cheek pad sizes Shoei also offer top centre pads in other sizes. You could remove the pad and note the size (and if you have some thinner sheet foam, like from packaging, try a piece in there for feel) if you think it would be worth investing in a thinner pad (if there is a suitable size).
I don't know what the standard thickness pad is or if the following reflects all available sizes or just what they have in stock, may need some more searching?
https://www.helmetcity.co.uk/shoei-centre-pad-neotec-2/
Shoei 2019 catalogue states cheek pads in 31, 35 & 39mm but only says available in various thickness for the top pad.
Online tcbandituk
  • Bike: 2018 XRt
« Reply #8 on: April 06, 2019, 01:39:20 PM »
You can compress the liner slightly to give a better fit.
I had an Arai Chaser V helmet that did the same.
I came across the Arai Service guys while I was in the Isle of Man shortly after buying it and complained to them about it.
The guy basically used the handle of a stubby screwdriver to slightly compress around the forehead area.
It was fine after that.  :002:
2015 Bonneville Speedchurch
2018 Speed Triple RS
2018 Tiger 800 XRt
TC Drag Bike
Offline Fuge
« Reply #9 on: April 06, 2019, 06:36:00 PM »
Thanks again for the encouragement chaps and for the link Stevie.P. I had a nose and it seems I'll most likely have the standard 9 mm thickness and could opt for the 5 mm for about 70.
It could mean a lot of faffing to no result: I've resigned myself to taking the hit. It will teach me not to rush such weighty decisions in future. It also means that someone gets a bargain and perhaps a higher quality lid than they might have otherwise - a difference that just save their life.
And I get lots of good Karma, so all is well.  :123:
