Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Transfer foglights from 2013 800 ABS to 2016 XRX  (Read 220 times)
Offline philmcglass
  • Mine's a pint
  • Bike: Tiger XRX 2016
« on: April 12, 2019, 05:12:31 PM »
I removed the foglights from my 2013 800 with a view to fitting to new (to me) 2016 XRX.
Doesnt look as simple as I had anticipated.
Wiring diagram for XRX shows that the lights are powered direct from the switch with no relay.
Presumably intended that lower power LED fog lights are to be fitted.
I wonder if anyone else has tried this installation?
My switch has 5 wires but the connector on the XRX has only three contacts.
Anybody know which wires I'd need to use?
I assume I need to retain the relay from the old wiring loom to handle the power.
Phil
Find the Line
Offline philmcglass
  • Mine's a pint
Re: Transfer foglights from 2013 800 ABS to 2016 XRX
« Reply #1 on: April 15, 2019, 01:42:33 PM »
Had  a closer look at the lights.
Appear to be LED so measured current from battery.
Only half amp.
I guess I can just plug in to XRX loom and use the newer switch available from Lings.
Gonna spruce up the metalwork brackets - need a respray.
Find the Line
