Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2016 XRX Chain links 124 or 122  (Read 533 times)
Offline Ross63
  • Bike: 2016 Xrx 800
« on: April 13, 2019, 01:05:32 AM »
Just bought a new DID chain for my 2016 XRX 800 with 124 links but the wheel is way back with less than 10mm of adjustment left. Looks like I could make it 122 and have much more adjustment left. Front sprocket is a 16 and rear 50 tooth. Is removing 2 links a wise move? Thanks
« Last Edit: April 13, 2019, 01:09:06 AM by Ross63 »
Offline SOHUTAA
  • Bike: Tiger 800 Xcx
Re: 2016 XRX Chain links 124 or 122
« Reply #1 on: April 13, 2019, 08:05:34 AM »
A chain that relaxes 10mm on 124 link, this represents 1 important wear !!
The swingarm is misleading because it seems to allow a greater amplitude of adjustment.
« Reply #2 on: April 13, 2019, 02:05:56 PM »
You're not likely to use more than 4mm of adjustment, then the chain is kaput.
« Reply #3 on: April 13, 2019, 04:47:09 PM »
The triumph wear limit test still applies. All you would achieve is a false sense of security and probably over wear the chain.
« Reply #4 on: April 13, 2019, 04:54:19 PM »
*Originally Posted by Ross63 [+]
Yes, that's the way it is on standard sprockets.
https://www.tiger800.co.uk/index.php/topic,24021.0.html
Adjustment on the ZVMX chain has been minimal so far so no idea when/if I will ever get to try removing 2 links as I posted (probably more for interest about 122 link fitting than getting more life out of it). :084:
« Last Edit: April 13, 2019, 04:56:31 PM by Stevie.P »
Offline Ross63
« Reply #5 on: April 21, 2019, 10:10:15 PM »
Thanks for the advice. I stuck with 124 links and now that I have to replace the rubbing strip I now understand I need that extra 2 links to move the wheel forward enough to get the chain off the rear sprocket!
« Reply #6 on: April 22, 2019, 12:11:25 AM »
Before you installed the new chain did you not follow standard procedure and lay it and the old chain side by side on the ground to confirm the length?
