Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Gearbox issues  (Read 438 times)
Offline Djalz
  • Bike: Triumph Tiger 80
Gearbox issues
« on: April 15, 2019, 07:05:58 PM »
A Friend of mine who has a used bike shop and a workshop tells me that he recently took a 2012 tiger with just over 9k on the clock. He sold it on as a part ex . he says the bike is now back in the workshop with the new owner reporting that the bike will go up through the gears but wont go back down. The engine is coming out and gearbox stripped and repaired . Has anyone came across this?
Online Rtwo
Re: Gearbox issues
« Reply #1 on: April 15, 2019, 07:07:44 PM »
Lots of people have come across this
It's either the selector return spring or the rivet in the end of the selector shaft
If it is the rivet: I welded mine but you can also tap and screw it
« Last Edit: April 15, 2019, 07:10:52 PM by Rtwo »
Offline healdem
  • ....has a fluffy tube
  • Bike: 2011 Tiger 800
Re: Gearbox issues
« Reply #2 on: April 15, 2019, 07:13:08 PM »
Agree with RTWO. Its a known fault. On the good news I don't think he needs to sttip the bike down and engine out. Im pretty certain the spring or detent pin can be accessed through the clutch.
There's enough posts on here to give an idea of how to approach the job. If not I'm sure others will assist
Offline jimmy60
  • Bike: 12 Blk Tiger 800
Re: Gearbox issues
« Reply #3 on: April 15, 2019, 09:58:58 PM »
Had mine repaired around 45K miles (pin) under warranty, then last month again at 86K miles. Both of the pins that sheared off were the earlier version which was not held as solid as the new one I put in. It looked much better. No reason for engine to come out.  :028:
Time and tide wait for no man.
Offline skidmark66
Re: Gearbox issues
« Reply #4 on: April 16, 2019, 06:56:50 AM »
Agree with the above do not remove engine until a proper inspection has been done otherwise your mate will get his pants pulled down for an easy fix.
Re: Gearbox issues
« Reply #5 on: April 16, 2019, 08:04:07 AM »
*Originally Posted by healdem [+]
... I don't think he needs to sttip the bike down and engine out. Im pretty certain the spring or detent pin can be accessed through the clutch.
:0461: . I keep a couple bookmarked just in case. :148:
https://www.tiger800.co.uk/index.php/topic,9167.50.html
https://www.tiger800.co.uk/index.php/topic,5185.70.html
