T800XC...I,ve used your tigertool & reset my faults,etc on my tiger 800 xrt 2019..thanks very much for that. Now the problem I have is :-
My bike ( recently bought with front end damage) , had a smashed led headlight, faulty, fuse blown/ replaced but still faulty( actually smashed case etc )..so I bought a used 1, with same manafucturing part no, same year, & told in working order..so, I fit it, but still not working, ..wiring was damaged when I bought it, and I repaired the wiring..at the headlight plug I got 12v standing on black, green is switched 12v from ignition, thick blue is earth, and red& blue canbus. I,ve tested cables & all seem OK. Canbus pair have approx 50 ohms between them with battery disconnected..( I assume 120 ohms at each end of canbus ..) ..fog light also not working.. As bike is new& I,m not familiar with operating I read book to see when headlights come on..so, I start bike & no headlights/ fog lights ( rear light OK )...I can see from your blogs that you are very familiar with the triumph & wondering if you have any idea ? Cheers, Steve ( s.wales , UK).
