Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Help will not turn over  (Read 291 times)
Offline ColinXCX
  • Bike: 2017 Tiger XCX
« on: April 22, 2019, 11:17:56 AM »
I need help, I went to start my 2017 XCX but it will not turn over, the temp is flashing with all the bars showing, the fuel bars are not showing but I have fuel. I've checked the battery and the fuses all good, I looked for the 30amp fuse under the battery but can not find it....Help me please.....
Offline andyrut
  • always willing to the extra mile
  • Bike: Roadie
Re: Help will not turn over
« Reply #1 on: April 22, 2019, 11:20:18 AM »
The thirty amp fuse is locate
d under the battery in the battery compartment.
Honda Varedero
Kawasaki Versys
Tiger 800 ABS
Offline andyrut
  • Bike: Roadie
« Reply #2 on: April 22, 2019, 11:21:53 AM »
If you have a volt meter check the voltage on the battery - if it is less then approx 12 volts the bike will not function - but the battery from factory at its age should be all good so might be a temporary drain from something
Another one is something I have done and that is accidently hitting the kill switch - yeah I know its numpty but .. :)
« Last Edit: April 22, 2019, 11:24:19 AM by andyrut »
Honda Varedero
Kawasaki Versys
Tiger 800 ABS
« Reply #3 on: April 22, 2019, 11:36:07 AM »
:084: any alarm system fitted?
Offline ColinXCX
« Reply #4 on: April 22, 2019, 12:10:32 PM »
Panic over, it was the kill switch. I sprayed some switch cleaner in it cycled it a few times now all good...thanks for the replies....
Offline JonesTheBass
  • Bike: Tiger 800XRx
« Reply #5 on: April 22, 2019, 07:11:07 PM »
I had to do something similar on the starter switch recently, 2015 bike; WD40 seems to have done the trick.
