Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: LED Indicators  (Read 2293 times)
Offline YellowTiger
  • Bike: 2011 Tiger 800
Re: LED Indicators
« Reply #10 on: June 24, 2019, 07:45:54 AM »
From memory the relay for the indicators on the pre 2015 Tigers is located in the space under the luggage rack immediately in front of the tail light. Post 2015 Tigers do not have a flasher relay it is controlled by the ECU in the dash console.
This was correct for my bike, and after taking the luggage rack off and disconnecting the relay, it was very obvious what needed to be done. I created a jumper between the two points and the lights are working as expected now. Thanks
Offline YellowTiger
Re: LED Indicators
« Reply #11 on: June 24, 2019, 07:48:39 AM »
Thanks everyone. I did manage to get them fully working, and it was exactly as you have all said. Simply take off the back box, pull the relay and put a jumper across the connector's two wires. Job done. :046: :046:
Online chuckxc
Re: LED Indicators
« Reply #12 on: June 24, 2019, 08:07:31 AM »
so in summary, I think what you have found is that the LEDs have their own built in flasher circuitry and don't need the single flasher unit originally on the bike.
Offline SteveTT800XRT
  • Bike: 2016 TT800XRT
Re: LED Indicators
« Reply #13 on: August 21, 2020, 06:42:27 PM »
Is there anyway you can change the ECU to stop the "hyper flash" ?
Online chuckxc
Re: LED Indicators
« Reply #14 on: August 21, 2020, 10:30:41 PM »
*Originally Posted by SteveTT800XRT [+]
What indicators are you using that causes your bike to "hyper flash"?
Do they have a built in flasher similar to the type discussed in the previous posts, or just straight LEDs?
Re: LED Indicators
« Reply #15 on: August 22, 2020, 01:03:34 AM »
I just used 15ohm resistors one on each side of the bike. They have worked perfectly for 4 years and 40,000 km so far.
Online chico
Re: LED Indicators
« Reply #16 on: August 29, 2020, 05:27:53 AM »
I have an issue related to this topic. After installing the new front LED indicators they worked except for the hyper flash speed.
 Then proceeded to the rear and now both front and rear aren't lighting. I then added a resistor to the wiring and still no lights.
The bike is a 2017 XRX and the directionals are the sequential types. Additionally, If I hold the directional button/lever the first few LED's stay lighted.
Any suggestions?
Re: LED Indicators
« Reply #17 on: August 29, 2020, 10:35:22 PM »
...new front LED indicators...bike is a 2017 XRX and the directionals are the sequential types.
Any suggestions?
I think this has been discussed elsewhere, previously?
I think the determination was: sequential LED turn signals need a constant 12V applied to work properly and can work on early T800s by removing and jumpering the flasher.
Later T800s get an on-off, flashing, 12V from the ECU (no separate 'flasher') -- it might not be possible?
Online chico
Re: LED Indicators
« Reply #18 on: August 30, 2020, 04:59:59 AM »
Well, I went back to do more tinkering today. While deliberating overnight I had a thought that perhaps what was needed was a resistor for each signal. So I added one to the other side of the rear. Still no good. Then I added a resistor to the right front and they all worked. :047: To summarize, it took three resistors to make all the directioals work properly, flashing sequentially.👍
Offline SOHUTAA
  • Bike: T800 Xcx 2016
Re: LED Indicators
« Reply #19 on: August 30, 2020, 07:46:43 AM »
The fact of having several resistors in series increases the impedance.
Putting them in parallel, on the contrary, lowers this value !!
To switch from original turn signals to leds, I added a resistor per side with a value of about 10 Ohms, and perfect operation.
