Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: LED indicators hyper flash with Triumph LED relay  (Read 841 times)
Re: LED indicators hyper flash with Triumph LED relay
« Reply #10 on: June 11, 2019, 08:24:41 PM »
Good decision, forget about the resistors and the Triumph electronic flasher. The low cost readily available solid state flashers like the one suggested below are good value and hassle free. You adjust the flash rate once when you install them and your done. Ive never had any problems with them.
Offline Maxrock
  • Bike: Tiger 800 ABS
« Reply #11 on: June 12, 2019, 07:50:35 PM »
SUCCESS!!!
Relay fitted, flash rate adjusted. Happy days, used the sub-harness from the triumph relay so wires cut and the rubber holder also fits the adjustable relay so didn't quite waste the 20 quid for the triumph one.
Thanks for the help and advice chaps :152:
Offline Beardiexrx
  • Bike: xRx
« Reply #12 on: June 12, 2019, 07:56:08 PM »
Have you a link,or where do I get this relay?Is it the same as Audi style flashers?
Offline Maxrock
« Reply #13 on: June 12, 2019, 08:09:45 PM »
*Originally Posted by Beardiexrx [+]
Link is in reply 7 of this thread, from Londonglide.
But here it is anyway  :001:
www.ebay.co.uk/itm/PureTek-CF14-3-Pin-Adjustable-LED-Flasher-Relay-Car-Turn-Signal-Indicator-Light-/272665874287
