Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Need help. 2012 800 XC is puking coolant.  (Read 866 times)
Offline bcliff
  • Bike: 2012 800 XC
« on: June 13, 2019, 03:03:13 AM »
My 2012 800 XC has recently started puking coolant from the vent tube near the foot pegs.
The weather has been mild, not hot, and the rides have been calm and on pavement, so the bike is not working very hard. I haven't touched the coolant in 2 years so nothing new in terms of coolant level in the rad or expansion tank, the bike has not been dropped or on its side, engine doesn't seem to be running abnormally hot (the usual 5 bands on the temp gauge), and the rad fan kicks on as you'd expect.
Any thoughts?
Re: Need help. 2012 800 XC is puking coolant.
« Reply #1 on: June 13, 2019, 05:44:04 AM »
First thing I'd check is that the coolant isn't contaminated, if it is, it points towards a possible head gasket failure
Then check the pump is working, start it up with the radiator cap off and you'll hopefully see the coolant being pumped.
If all's good there, I'd replace the radiator cap.
I wouldn't normally throw parts at something but the thermostat is a PIA to get at
Offline Djalz
  • Bike: Triumph Tiger 80
« Reply #2 on: June 13, 2019, 12:55:29 PM »
Dunno if this is the problem but a few years back I had a GSXR 1000 K5 and it did the same thing , I heard all sorts of horror stories about head needing skimmed etc, found it to be the rad cap had lost tension in the spring and wasnt able to rise to realease pressure , new cap sorted it.
Hope this helps
Offline bcliff
  • Bike: 2012 800 XC
« Reply #3 on: June 14, 2019, 12:31:01 AM »
thanks guys.  I haven't had a chance yet to try and diagnose but this gives me a starting point.  much appreciated.
Offline grunty-motor
  • Bike: XCA
« Reply #4 on: June 14, 2019, 06:39:50 AM »
i had something similar with the zx6r and it was the radiator cap
Offline Turbotom
« Reply #5 on: June 14, 2019, 07:56:01 PM »
The radiator cap is relative cheap en would be the first part I would change in this case.
Tom
Tiger 800 XRx 2015 caspian blue
Offline bcliff
  • Bike: 2012 800 XC
« Reply #6 on: June 14, 2019, 07:59:35 PM »
*Originally Posted by Turbotom [+]
Tom
I've got a cap on order.  In the meantime, I'll be inspecting for oil contamination, making sure water pump is functioning, and searching for any other gremlins.  I appreciate the input I've received from this forum's members.
Offline sezian
« Reply #7 on: June 16, 2019, 02:02:29 PM »
I had the coolant boiling in the expansion tank and overflowing on my 2012 - New radiator cap cured the problem  :028:
Offline Nomad
  • Bike: Tiger XRx
« Reply #8 on: July 23, 2019, 02:57:08 PM »
OP Did you solve the problem? Ive got the same trouble. Cheers
