Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Hello everyone  (Read 215 times)
Offline Kalechip1
  • Bike: 2013 tiger 800
Hello everyone
« on: June 19, 2019, 12:33:41 PM »
Hell everyone new to this
Offline Kalechip1
Re: Hello everyone
« Reply #1 on: June 19, 2019, 12:36:44 PM »
Need help with this code on my tiger. P1108 - Ambient air pressure sensor circuit high voltage.  Has anyone everyone solved this?  Do I need to replace the sensor?  The wires that plugged into the sensor looked fine and the plugs for the sensor look good.  Need help on what to do
Re: Hello everyone
« Reply #2 on: June 19, 2019, 01:10:18 PM »
No experience of this fault but the workshop manual process for this code is:
Disconnect ambient pressure sensor
Check cable for short circuit: ECM pin A27 to ECM pin B01
OK - Renew ambient pressure sensor (and proceed to end *)
Short circuit - Locate and rectify wiring fault (and proceed to end *)
* Reconnect harness, clear fault code and run
OK Action complete, quit test engine
Fault still present - Contact Triumph service
ECM                   Wire                 Sensor
B20               -     KB (Pink/Black)         -          2
A27               -     KP (Pink/Purple)        -          1
B01               -       K (Pink)                  -          3
Hope this may help. :084:
« Last Edit: June 19, 2019, 01:11:55 PM by Stevie.P »
Offline Kalechip1
Re: Hello everyone
« Reply #3 on: June 19, 2019, 02:13:37 PM »
Ok thanks.   When you say renew sensor does that mean replace with new one?
Re: Hello everyone
« Reply #4 on: June 19, 2019, 04:48:15 PM »
Yes, based on the manual if it passes the wiring test then sensor is faulty.
Online Silverstripes
  • Avatar my 955i Tiger 2003/4
Re: Hello everyone
« Reply #5 on: June 19, 2019, 06:04:23 PM »
Hello and  :401:
It wasn't me !!
Offline Kalechip1
Re: Hello everyone
« Reply #6 on: June 20, 2019, 02:33:01 AM »
So is this the sensor that is under the battery?   The barometric sensor r
Re: Hello everyone
« Reply #7 on: June 20, 2019, 09:15:26 AM »
Yes, the barometric pressure sensor is located on the battery tray, under the battery.  :028:
