Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Code p1108  (Read 210 times)
Offline Kalechip1
  • Bike: 2013 tiger 800
Code p1108
« on: June 19, 2019, 12:48:58 PM »
Need help with this code on my tiger. P1108 - Ambient air pressure sensor circuit high voltage.  Has anyone everyone solved this?  Do I need to replace the sensor?  The wires that plugged into the sensor looked fine and the plugs for the sensor look good.  Need help on what to do
Offline D6864
  • Bike: White XC
Re: Code p1108
« Reply #1 on: June 19, 2019, 03:39:15 PM »
Service manual says:
- Disconnect ambient pressure sensor
- Check cable for short circuit: ECM pin A27 to ECM pin B01. That's the pink/purple to pink wires on the sensor cable (hope you're not colour blind like I am)
- If short circuit, locate and rectify wiring fault
 - If OK, renew ambient pressure sensor
- Reconnect harness, clear fault code and run engine
- If fault still present, contact Triumph service
