Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Oil level  (Read 4400 times)
Re: Oil level
« Reply #20 on: August 12, 2019, 03:42:41 PM »
*Originally Posted by ZenDog [+]
I have found the correct oil level fills the window when cold (and the bike level), any gap tells me its low. This is a far easier and quicker way of checking because I rarely follow the unnecessary complicated and vague procedure out side of oil changes.
Just look at it after you've filled up with fuel, it at temp and settled, nothing complicated, unnecessarily so or other.
Offline ZenDog
  • Bike: 800 XCX
Re: Oil level
« Reply #21 on: August 12, 2019, 04:45:58 PM »
Yep, that is another way, but you don't have any oil at hand (other than buying some) to top up if desperately needed.
Re: Oil level
« Reply #22 on: August 12, 2019, 08:31:03 PM »
...but you don't have any oil at hand (other than buying some) to top up if desperately needed.
Any oil in the sight-glass is plenty -- low oil level is below the low level line on the sight-glass (and, that's still about a gallon of motor oil).
On a side note does the oil usually look dark in the window?
Color of motor oil isn't much of an indicator of quality -- UOA (used oil spectrographic analysis) can determine quality and doesn't reference color at all.
Offline Derchef1962
  • Bike: 800 Roadie, 2013
Re: Oil level
« Reply #23 on: August 12, 2019, 09:13:20 PM »
:0461: On the centre stand (provided you have one) it takes no effort to gently tip the bike back or forward and balance it to get the oil level relative to the marks.
exactly and you will also find out that the raised back wheel does not make much of a difference regarding the oil level. I put a piece of wood under the front wheel to level the bike on centre stand
Re: Oil level
« Reply #24 on: August 12, 2019, 09:31:38 PM »
If the glass is full how do you know what the level really is. Overfilled with oil can cause various detrimental results ... definately not a method to be encouraged.  :110:
Offline Derchef1962
Re: Oil level
« Reply #25 on: August 12, 2019, 11:59:01 PM »
and if the glass is full when the engine is cold there is definately too much oil
Offline ZenDog
  • Bike: 800 XCX
Re: Oil level
« Reply #26 on: August 14, 2019, 12:26:00 PM »
*Originally Posted by RockyMtn800 [+]
Note: An accurate indication of the level of oil in the engine is only shown when the engine is at normal operating temperature
I wish it indicated correctly when cold
Offline Derchef1962
Re: Oil level
« Reply #27 on: August 14, 2019, 04:17:13 PM »
don't think you can: Oil expands when it gets hot for one thing cold oil tends to cling to certain parts of the engine so not all oil will run back in to the oil sump. Oil needs to be warm to checked.
My Tiger has now about 72,000 kms on the clock, my oilcheck is dead simple. When I stop for fuel or something I put the bike on the centre stand, let the oil settle (typically that's the time I need to fill up and pay), check the level end of story. If I am totally anal about it I will level the bike on centre stand by putting a piece of wood under the front wheel but in most cases I do not bother.
Very easy in fact compared with my bobber where the oil glass is so tiny and so hiden it's a nightmare to check oil level.
Re: Oil level
« Reply #28 on: August 14, 2019, 05:11:25 PM »
If you check it after you've fuel up each time, it won't have changed much in the last 200 miles so could just wait till you get home
Offline troubleshooter
Re: Oil level
« Reply #29 on: October 20, 2019, 10:14:13 AM »
Given the idiosyncrasies of checking the oil level, how do you make sure you don't overfill initially when doing an oil and filter change? Put in less than the spec to start with?
