Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
March 07, 2021, 02:16:47 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Changing rectifier
Print
Pages: [
1
2
3
Go Down
Author
Topic: Changing rectifier (Read 2901 times)
ghulst
Tiger Member
Bike: Tiger 800 XC
Changing rectifier
on:
August 20, 2019, 07:54:06 PM »
I am taking delivery of a Tiger which probably has a shot rectifier. I’ve already gotten one from a breaker, as it was too good a deal to pass up. Anyway, are there any how-to’s on the subject? Just wondering whether I need to take the whole thing apart, or whether I can get away with just loosening up the radiator to wriggle it in. ;)
(By the way, I did read up on the air filter change and it seems not much has changed since the steamer... It still is a heck of a lot of work. :icon_lol:)
Logged
‘11 Triumph Tiger 800 XC / '94 Ducati 600 SuperSport
TigerNige
Tiger Pro
Bike: Tiger 800 Road
Re: Changing rectifier
Reply #1 on:
August 20, 2019, 10:39:40 PM »
I got away with a lot of wriggling ! loosened off / removed the top bolts - some serious fiddling around but no major removal or draining.
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Bike: 2015 Tiger XRt
Reply #2 on:
August 21, 2019, 12:29:56 AM »
Originally Posted by
ghulst
… Just wondering whether I need to take the whole thing apart, or whether I can get away with just loosening up the radiator to wriggle it in. ;)
Hi and
You haven't said what year or generation Tiger … Gen 1 or Gen 2?
If Gen 2 (as I have done it) simply remove the lower plastic radiator panels below fuel tank, remove 1 radiator bottom fixing bolt and 1 top fixing bolt. Radiator can then gently be moved forward on the hoses and allow access to the RR.
I do have a series of pics I took for a 'How To' but like another 101 other things it is on my waiting to be done list.
Logged
TigerNige
Tiger Pro
Reply #3 on:
August 21, 2019, 09:44:25 AM »
Mine is a gen 1 2012. Was much the same as Stevie.P Thought I managed to leave the bottom bolt in and got away with leaning the rad forward? Not quite sure now as I also had a radiator guard to remove. not a technical problem to do but very fiddly ! Good luck !
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Reply #4 on:
August 21, 2019, 11:08:03 AM »
TigerNige
I removed top and bottom bolts but didn't remove the (Triumph) radiator guard (and also have Triumph engine bars fitted). Hardest part I had was actually getting the 2 plugs off the RR before unbolting, even with a drowning of WD40. New RR pins and harness plugs were treated to a bit of electrical contact grease (Contralube 770).
Logged
TigerNige
Tiger Pro
Reply #5 on:
August 21, 2019, 12:49:36 PM »
Ahhh........ Forgot that bit ! The plugs were a b***** pain ! probably because of the heat, and in my case the molten resin !
Logged
ghulst
Tiger Member
Bike: Tiger 800 XC
Reply #6 on:
August 21, 2019, 09:44:12 PM »
Mine will be a Gen 1 ‘11 model. I am pretty sure the rectifier is shot and as I have a replacement anyway, I’ll just do that and a new battery to see if that solves the charging problem. If not, I can always go and measure some more. ;)
Thanks for your help. Plugs always are a *****. I’m assuming these will have been in for a while. I do have some electrical spray, so I might put some one, just to be sure. And wiggle. Lots to wiggle. ;)
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Reply #7 on:
August 21, 2019, 10:21:11 PM »
ghulst
Is the bike starting up? If so and you have a multimeter check the battery voltage with the engine off then with the engine running. If the RR is shot likely it will rectify the alternator output but have failed on the voltage regulation side. You want around 14v when running …. not the 19.6v I had.
https://www.tiger800.co.uk/index.php/topic,22590.10.html
As for the plugs, purely such a tight dry interference fit on the plug to socket faces and only just getting your hand in there.
Logged
ghulst
Tiger Member
Bike: Tiger 800 XC
Reply #8 on:
August 22, 2019, 07:06:03 PM »
Oh, just in case I want to really go over the whole system... Can I measure the alternator without taking it out of the bike? Where can I find those plugs? I do have the workshop manual, but don’t have the bike here yet. ;)
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Reply #9 on:
August 22, 2019, 10:20:59 PM »
ghulst
I don't know if there are easier connectors from the alternator that you can access to test it? But the ones needed to change the RR definitely need the radiator off its mounts for reasonable access.
(having found my pics I could do a 'how to' - though it isn't that common a failure based on posts here
Logged
Print
Pages: [
1
2
3
Go Up
Changing rectifier
Another lowering question
6172dave
Today
at 12:38:07 AM
TPMS
Tyres and Wheels
UncleGary
Yesterday
at 11:38:26 PM
Vehicle speed sensor malfunction
Mally110
Yesterday
at 10:42:02 PM
Happy Birthday x10
Londonglide
Yesterday
at 07:35:19 PM
Engine management light on after dead battery
6172dave
Yesterday
at 07:33:33 PM
Where to fit Sat Nav on new 2018 Tiger 800
applecorp
Yesterday
at 07:26:05 PM
Quick mock up for a sat nav mount
Sat Navs, Intercoms, Cameras, and other tech gadgets
chico
Yesterday
at 06:02:55 PM
Genuine Triumph Adjustable Touring Screen - New & Unused - A9708399
For Sale
2wheelstony
Yesterday
at 05:45:27 PM
Nee member with gearing query
New Members
D6864
Yesterday
at 05:30:23 PM
return to triumph
New Members
freeware
Yesterday
at 04:50:47 PM
