Members Practice Area > "Test and Tryout"
Rook McRookerton
(1/1)
MrSpiff:
The heated grips on my 15 XRX are worn down and get very sticky/tacky. I spoke to the dealer near me and asked if I could cut the rubber part off and replace and they said "No you have to buy a new set."
Does anyone have knowledge beyond that. Ideally I'd like to just cut the rubber off and slide new ones on.
Is that possible?
Until I learn more I've bought some baseball bat tape which has eliminated some stickiness and still lets heat through.
UncleGary:
The grips have the heating element molded into the rubber. There is a wire to connect that supplies the current. So some disassembly/assembly required.
https://www.triumphinstructions.com/ProdDocs/A9638172-EN.pdf
Good luck
MrSpiff:
my wallet was afraid of that, thanks
Stevie.P:
 If they are working but simply sticky why not just fit a pair of 'Grip Buddies' or plenty of similar.makes.
https://www.nippynormans.com/grip-buddies/grip-buddies-vibration-elimination-grip-covers-harley-and-triumph
MrSpiff:
wil check them out, thanks
