Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: How to fit a Givi top box  (Read 1452 times)
Offline Fazer
  • Bike: Tiger 800XRt
Re: How to fit a Givi top box
« Reply #10 on: August 27, 2019, 12:37:08 PM »
Almost identical to my solution, Stelyn. Great minds think alike!
Offline ghulst
  • Bike: Tiger 800 XC
« Reply #11 on: August 28, 2019, 03:02:29 PM »
I found a universal luggage rack for the Tiger for 45, so I ordered that and if it works, I'll put the Givi box on that. If not, I was considering going the same way with two metal straps. How thick did you make yours and from what material exactly?
11 Triumph Tiger 800 XC / '94 Ducati 600 SuperSport
Offline Fazer
« Reply #12 on: August 28, 2019, 04:24:51 PM »
My straps are 210 x 20 x 3mm stainless steel.
Offline ghulst
« Reply #13 on: August 28, 2019, 07:40:57 PM »
*Originally Posted by Fazer [+]
Thanks Fazer. Sounds obtainable.
Btw. does anyone have a picture of the way the rack for the original Triumph Adventure cases are mounted? Or should I start a new topic for that? I just picked up a pair for a steal. ;)
Offline markymark11
  • Bike: 800
« Reply #14 on: August 29, 2019, 07:40:28 AM »
If you go to the first web site - World Of Triumph - find your part number, and then the second web site Triumph instructions shows you how to fit them.
https://www.worldoftriumph.com/partscatalog/catalog/select/catalog/triumphmc/method/model/
https://www.triumphinstructions.com
Offline ghulst
« Reply #15 on: August 29, 2019, 09:27:19 AM »
Thanks. I'll check it, but the World of Triumph site seems to be down (for me) right now. :(
Offline ghulst
« Reply #16 on: August 29, 2019, 11:09:43 AM »
And its back, and I found it. :) Thanks!
Offline ghulst
« Reply #17 on: September 01, 2019, 09:27:39 PM »
Just to keep all of you updated, I found a nice rear luggage rack that fits the top plate. I drilled four extra holes in it to mount the Givi. If I want to, I can also pull the Givi off and just use it to strap stuff to. Pretty happy about it for about 40.
By the way, the Tiger came with three extra lock cylinders. Would a Triumph cylinder fit the Givi Monokey? Does anyone know?
« Last Edit: September 01, 2019, 09:52:37 PM by ghulst »
