Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Ambient temperature gauge way off  (Read 3109 times)
Offline Abbienormal
  • Bike: 18 Tiger 800 Low
« on: August 29, 2019, 01:39:03 AM »
I have a question on the air temperature reading on the 2018 Tiger. I have a 2018 and it reads way low. It appears to be on a scale as the hotter it is the farther off it is. Not sure where it is a lower temperatures yet but comparing it to another bike with a gauge that read the same as several other bikes in the past at 92 degrees (F) mine says 85. At 73 it reads 68. Any cure? Brother has a 2019 and his read about the same as mine plus 1 degree.  Problem is one other bike with a known accurate thermometer and the phones and outside temperatures were all higher.
Re: Ambient temperature gauge way off
« Reply #1 on: August 29, 2019, 04:15:41 AM »
The temperature gauge sensor on the pre 18 models is located directly on top of the headlight under the instruments as in the picture below. I expect the later bikes are probably in the same location. it could be worth checking to see if there is anything obstructing air flow to it but I guess that would probably tend to make it run hot.
The gauge on my bike is very accurate within maybe 1/2 degree C. It is consistently about 1.5 degrees cooler than my Ducati which has the probe located in a place much more effected by engine heat.
Maybe the gauge can be recalibated using Tiger Tools or such similar software.
« Reply #2 on: August 29, 2019, 09:19:18 AM »
It's a 2018. It's under warranty. I know where I'd be going.
Lost again
« Reply #3 on: August 29, 2019, 09:47:45 AM »
:0461:
Offline Oldbear
  • Bike: 2018 800 XRT
« Reply #4 on: August 31, 2019, 09:54:55 PM »
My 18 XRT is pretty much on the button.    Id say let the dealer check it out under warranty.
Online Rtwo
« Reply #5 on: August 31, 2019, 10:28:47 PM »
My mates Speed Triple RS is at least 5 degrees (C) under reading, the dealer said they couldn't find an issue  :015:
My KTM was spot on and then went screwy so had to replace the sensor, 15 later it's back to spot on.
