Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Drain Plug give up  (Read 1926 times)
Re: Drain Plug give up
« Reply #10 on: September 17, 2019, 09:43:48 PM »
*Originally Posted by Baetech [+]
...obviously this bolt had a fusion problem
here some pics of what happen.
Please share your story
That plug doesn't look like OEM.
the replacement part is exactly the same, including material,,,,can you elaborate more please...
I enlarged the upper photo -- and, it appears the the drain plug has a 12 point inner hex?
My T800, that I had from new and I only changed oil, has a 6 point inner hex?
So, at least it's different from mine..?  :187:
Offline Bladerunner99
  • Bike: 2018 XCA
« Reply #11 on: September 18, 2019, 11:53:42 AM »
Just checked my 2018 XCA, 6 point hex also.  I suggest if yours is 12 point, then it is most likely an aftermarket part.
Ride to work. Work to ride
Offline Robzulu80
  • Bike: 2015 800 XCx
« Reply #12 on: September 18, 2019, 12:17:14 PM »
Looks like a normal 6 point torx to me
« Reply #13 on: September 18, 2019, 03:41:38 PM »
Oh, I didn't consider it being a Torx -- in that case, also different.
Mine, an original, is a regular hex-socket "Allen" style.
Offline Robzulu80
« Reply #14 on: September 18, 2019, 04:04:54 PM »
Could be a Mangled Allen key aswell haha
Either way its rather unfortunate
« Reply #15 on: September 18, 2019, 05:30:17 PM »
..... it appears the the drain plug has a 12 point inner hex?
*Originally Posted by Robzulu80 [+]
I think it is a normal hex key but the countersink gives an optical illusion to the contrary?
Offline Robzulu80
« Reply #16 on: September 18, 2019, 05:49:42 PM »
Id say u are right! I stand corrected 😁
Offline Baetech
  • Bike: tiger 800XRt
« Reply #17 on: September 20, 2019, 04:51:41 PM »
You are correct, is a 6, just an optical illusion.
Here's an update: After further inspection, (im an engineer) i took the part to our metal and non destructive testing lab and they did an analysis of what happen that lead to bolt flange failure, the conclusion : In the manufacturing process a bobble of gas was formed before the filling material (metal) was able to completely fuse, therefore the trapped air/gas created a weak point that will later cause a crack thru the tread flange in an attempt to go into the thin/weaker part of the bolt, due to the pressure applied from the oil pan against the tread, the flange (shoulder) took the damage as the only part of the bolt not having any external force impeding for the crack to spread.
In other words, the crack couldn't continue into the tread and it forced the flange to give up, this lead us to believe that the bolt may been cracked since day one but never noticed.
i hope this helps someone in the future, thanks for sharing toughs.
Offline prenticemarie
« Reply #18 on: September 21, 2019, 11:59:39 AM »
Fascinating heads-up "Baetech" ... Lucky to have access to experts ...  :031:
My My, How Time Flies ... 61 Years ... From BSA DBD34 Gold Star To Tiger 800 Road ... 1959 - 2020 !
