Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Where to install Denali Mini Soundbomb on Tiger 800 XRT 2019?  (Read 2800 times)
Offline Q
  • Bike: 800 XCA
Re: Where to install Denali Mini Soundbomb on Tiger 800 XRT 2019?
« Reply #10 on: September 30, 2019, 04:37:53 PM »
I think some of you guys are confusing the compressor driven Sound Bomb with the standard OEM replacement horn the Sound Bomb Mini that the OP asked about.
The Mini as in my photo above is simply a direct replacement for the OEM horn and uses the same two spade terminal leads as the OEM horn.
 :028:
« Reply #11 on: October 04, 2019, 10:22:45 PM »
*Originally Posted by Q [+]
try switching the wires on the soundbomb itself - mine came with a set of instructions which switched the polarity and caused the compressor to run in reverse (with the meep meep sound :-)
It's a Mini (not a compressor one) and it used to work.
Offline petesear
  • Bike: XRT
« Reply #12 on: October 04, 2019, 10:42:33 PM »
They don't work when they are full of water as I discovered.. just saying...
Offline Newhorizons
  • Bike: 2015XC
« Reply #13 on: November 10, 2019, 12:09:46 PM »
FWIW, I mounted a Mini Sound Bomb up under the screen of my Madstad. (It doesn't fit in the std horn position under the beak)
Having said that (and the reason for my post)
What a waste of money... they said it was louder than standard ... back to the catalogs to buy a 12 volt horn that actually makes a 'here I am noise!'
Offline bucksfizz
  • Bike: 18 Tiger 800 XRT
« Reply #14 on: November 10, 2019, 03:04:56 PM »
*Originally Posted by Newhorizons [+]
I've yet to do the same job to the Tiger 800, but I did install twin FIAMM horns to the Street Triple:
IIRC, they cost about 18 for a pair.
They need a relay to drive them (included in the box):
Then wire them directly to the battery with an inline fuse.
And you need to locate them somewhere:
When everything is installed, they sound just like a good car horn, and gave my MoT tester a bit of a fright.
One day I'll get round to doing the same job on the Tiger - definitely worthwhile.
Offline Newhorizons
  • Bike: 2015XC
« Reply #15 on: November 11, 2019, 05:06:14 AM »
Bucksfizz. Your the Man.
Thats exactly what I have on my Bandit and there awesome. Saved my bacon a few times.
Will look around coz even one would probably do the trick.
« Reply #16 on: November 11, 2019, 06:26:34 AM »
Maybe the Madstad is deadening the sound. Mine is way louder than stock with a much deeper note but it is out in the open.
Offline Newhorizons
  • Bike: 2015XC
« Reply #17 on: November 11, 2019, 07:27:42 AM »
Nah, its just a dud.
It sits out in the open and wouldn't scare a spider walking past.
To be honest I should have fitted it to the std wiring first and tested it, could have saved myself a few hours building a mount and extending the wiring.
Offline applecorp
  • Bike: 800 XRT 2018
« Reply #18 on: March 03, 2020, 03:55:16 PM »
Bloody hell, like a numpty I didn't do my research properly, bought a soundbomb mini and for some reason assumed the OEM horn would be low down near the radiator as with most of my previous bikes, but no, it's tucked away in the mini beak (had to bloody Google it as I couldn't find it by sight and no chance will it fit in there.
Has anyone managed to fit the MINI to an XRT without trailing wires to some other part of the bike?
« Last Edit: March 03, 2020, 03:57:05 PM by applecorp »
Online david357
  • Bike: Tiger 800XRT
« Reply #19 on: March 03, 2020, 04:17:54 PM »
I havent ☹️
